What are the Wifi dongles with external antenna compatible with raspberry pi3 / OSMC? Because I bought this: http://www.gearbest.com/network-cards/pp_421909.html?wid=21 and could not install.
WiFi Dongle - Ultra Long Range High Gain w/ 5dBi Antenna
Tested for Compatibility with the Raspberry Pi
Plug & Play - Requires No Installation. Can be used straight from the GUI via the WiFi Config Program.
Plugs straight in the Raspberry Pi USB Port - Requires No External Power.
Ralink RT3070 Chipset
Features a 5dBi High Gain Detachable External Antenna for Extra Range. (Antenna Connector RP-SMA)
Fully CE Compliant to 2017 Standards (EMC EN 301 489-17 V3.1.1)
