after some help from the forum, I managed to run the OSMC wifi Dongle on MY RPI1 on 5GHz Network just fine.
I run my RP1 24/7 and it works flawlessly, but after 3 or 4 days of running without issues, the Dongle looses connection but does not reconnect to the wifi network.
I always have to pull power and make the rpi reboot to get Wifi again, and then it will work again for 3 to 4 days.
Does this problem sound familiar? Any way to avoid having to reboot after 3-4 days?
My other devices on the net do not have such problems, but they don’t run 24/7. And if they run, I dont have any issues.
I also don’t have any IP lease time restrictions set in my router.
The RPI seems responsive and fine except for no Wifi, unfortunately I run it headless and control it via App, and if the wifi is gone, I can not config it without any hassle, so I just pull the plug on the rpi.
Also this happens only after 3-4 days running so its hard to reproduce. maybe the logs can give a hint.
Try setting a static IP if you can. It would be interesting to know if that helps.
If you are able, after loss of connectivity, try attaching an Ethernet cable and running the log uploader.
Static IP kinda worked. Now I only lost connection after 2 weeks. And had to pull the plug then. Since Mid December I had only to pull it once. However the raspi still does not reconnect automatically after it looses connection by itself.
Your log is being spammed every 10 minutes with the group rekeying message. It’s not clear that this is the root cause of your problem but reducing the number of such rekeying events to, say, once every 24 hours might have helped. My own feeling is that the problem probably lies with the router.
