1 You should ideally have disabled your internal WiFi adapter by adding the line
dtoverlay=sdhost
to the file /boot/config.txt.
2 Unfortunately, your root partition failed a filesystem check:
Mar 17 21:14:47 osmc2 fsck: E2fsck run: /bin/e2fsck -p -C 0 /dev/mmcblk0p2
Mar 17 21:14:47 osmc2 fsck: Filesystem UUID: e358a45e-dc1d-4ffc-af6b-4bea5d38ba7f
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 2864 (uid=0, gid=0, mode=0100644, size=46548)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654123 (uid=0, gid=0, mode=0100644, size=200048)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654227 (uid=0, gid=0, mode=0100644, size=174988)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654244 (uid=0, gid=0, mode=0100644, size=14052)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654264 (uid=0, gid=0, mode=0100644, size=88740)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654634 (uid=0, gid=0, mode=0100755, size=137064)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654639 (uid=0, gid=0, mode=0100755, size=83732)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654655 (uid=0, gid=0, mode=0100644, size=1363568)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654129 (uid=0, gid=0, mode=0100644, size=50896)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654304 (uid=0, gid=0, mode=0100644, size=359344)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654120 (uid=0, gid=0, mode=0100644, size=46836)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654265 (uid=0, gid=0, mode=0100644, size=198132)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 9117 (uid=0, gid=0, mode=0100755, size=137108)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 3785 (uid=0, gid=0, mode=0100644, size=26262)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654135 (uid=0, gid=0, mode=0100644, size=9840)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654125 (uid=0, gid=0, mode=0100644, size=22540)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654243 (uid=0, gid=0, mode=0100644, size=55132)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654250 (uid=0, gid=0, mode=0100755, size=106972)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654260 (uid=0, gid=0, mode=0100644, size=30400)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654286 (uid=0, gid=0, mode=0100644, size=30372)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654258 (uid=0, gid=0, mode=0100644, size=13920)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654126 (uid=0, gid=0, mode=0100644, size=22364)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654148 (uid=0, gid=0, mode=0100644, size=55224)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654119 (uid=0, gid=0, mode=0100644, size=423484)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654134 (uid=0, gid=0, mode=0100644, size=9804)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654164 (uid=0, gid=0, mode=0100755, size=902996)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654302 (uid=0, gid=0, mode=0100755, size=101716)
Mar 17 21:14:47 osmc2 fsck: Clearing orphaned inode 654215 (uid=0, gid=0, mode=0100644, size=100044)
Mar 17 21:14:47 osmc2 fsck: Setting free inodes count to 881536 (was 883877)
Mar 17 21:14:47 osmc2 fsck: Setting free blocks count to 3236063 (was 3254652)
Mar 17 21:14:47 osmc2 fsck: /dev/mmcblk0p2: clean, 50528/932064 files, 491041/3727104 blocks
It looks like there are some problems, possibly related to the filesystem corruption, with the driver for the dongle:
Mar 17 21:14:47 osmc2 kernel: RTL871X: module init start
Mar 17 21:14:47 osmc2 kernel: RTL871X: rtl8812au v4.3.14_13455.20150212_BTCOEX20150128-51
Mar 17 21:14:47 osmc2 kernel: RTL871X: rtl8812au BT-Coex version = BTCOEX20150128-51
Mar 17 21:14:47 osmc2 kernel: ------------[ cut here ]------------
Mar 17 21:14:47 osmc2 kernel: WARNING: CPU: 2 PID: 226 at net/wireless/core.c:393 wiphy_new_nm+0x5a8/0x6b0 [cfg80211]
Mar 17 21:14:47 osmc2 kernel: Modules linked in: rtl8812au(O+) brcmutil cfg80211 evdev rfkill snd_bcm2835(C) snd_pcm snd_timer snd bcm2835_thermal bcm2835_gpiomem uio_pdrv_genirq fixed uio ip_tables x_tables ipv6
Mar 17 21:14:47 osmc2 kernel: CPU: 2 PID: 226 Comm: systemd-udevd Tainted: G C O 4.14.26-2-osmc #1
Mar 17 21:14:47 osmc2 kernel: Hardware name: BCM2835
Mar 17 21:14:47 osmc2 kernel: [<80117020>] (unwind_backtrace) from [<80111450>] (show_stack+0x20/0x24)
Mar 17 21:14:47 osmc2 kernel: [<80111450>] (show_stack) from [<80942780>] (dump_stack+0xc8/0x10c)
Mar 17 21:14:47 osmc2 kernel: [<80942780>] (dump_stack) from [<80128340>] (warn_slowpath_null+0x90/0x120)
Mar 17 21:14:47 osmc2 kernel: [<80128340>] (warn_slowpath_null) from [<7f2499a8>] (wiphy_new_nm+0x5a8/0x6b0 [cfg80211])
Mar 17 21:14:47 osmc2 kernel: [<7f2499a8>] (wiphy_new_nm [cfg80211]) from [<7f48b1f4>] (rtw_wdev_alloc+0x38/0x2c4 [rtl8812au])
Mar 17 21:14:47 osmc2 kernel: [<7f48b1f4>] (rtw_wdev_alloc [rtl8812au]) from [<7f475974>] (rtw_usb_if1_init+0xd8/0x224 [rtl8812au])
Mar 17 21:14:47 osmc2 kernel: [<7f475974>] (rtw_usb_if1_init [rtl8812au]) from [<7f475c90>] (rtw_drv_init+0x1d0/0x4a4 [rtl8812au])
Mar 17 21:14:47 osmc2 kernel: [<7f475c90>] (rtw_drv_init [rtl8812au]) from [<806ffb5c>] (usb_probe_interface+0x26c/0x3fc)
Mar 17 21:14:47 osmc2 kernel: [<806ffb5c>] (usb_probe_interface) from [<8066b274>] (driver_probe_device+0x3c8/0x4b8)
Mar 17 21:14:47 osmc2 kernel: [<8066b274>] (driver_probe_device) from [<8066b454>] (__driver_attach+0xf0/0x110)
Mar 17 21:14:47 osmc2 kernel: [<8066b454>] (__driver_attach) from [<80668674>] (bus_for_each_dev+0x78/0xac)
Mar 17 21:14:47 osmc2 kernel: [<80668674>] (bus_for_each_dev) from [<8066a40c>] (driver_attach+0x2c/0x30)
Mar 17 21:14:47 osmc2 kernel: [<8066a40c>] (driver_attach) from [<80669f9c>] (bus_add_driver+0x114/0x220)
Mar 17 21:14:47 osmc2 kernel: [<80669f9c>] (bus_add_driver) from [<8066bdc4>] (driver_register+0x9c/0x11c)
Mar 17 21:14:47 osmc2 kernel: [<8066bdc4>] (driver_register) from [<806feaa0>] (usb_register_driver+0x80/0x144)
Mar 17 21:14:47 osmc2 kernel: [<806feaa0>] (usb_register_driver) from [<7f57309c>] (init_module+0x9c/0x1000 [rtl8812au])
Mar 17 21:14:47 osmc2 kernel: [<7f57309c>] (init_module [rtl8812au]) from [<801021b8>] (do_one_initcall+0x54/0x17c)
Mar 17 21:14:47 osmc2 kernel: [<801021b8>] (do_one_initcall) from [<801dc04c>] (do_init_module+0x74/0x350)
Mar 17 21:14:47 osmc2 kernel: [<801dc04c>] (do_init_module) from [<801daf68>] (load_module+0x29cc/0x2d14)
Mar 17 21:14:47 osmc2 kernel: [<801daf68>] (load_module) from [<801db4c4>] (SyS_finit_module+0xb8/0xc8)
Mar 17 21:14:47 osmc2 kernel: [<801db4c4>] (SyS_finit_module) from [<8010c5c0>] (ret_fast_syscall+0x0/0x28)
Mar 17 21:14:47 osmc2 kernel: ---[ end trace af2d1fe19c0460e0 ]---
I think you’re looking at a reinstall, ideally on a fresh SD card.
Edit: Fixed typo.
