The access point is 1000mw and it is 15 feet from the Pi. The dongle connects fine if the OS is Raspbian.
I tried 3 different power supplies with both a Pi3 and the Pi2 with the Edimax WiFi dongle. The Pi3 connects every time but the Pi2 does not. Voltages are with OSMC running and stopped.
OK, I have resolved the problem and learned something interesting. When I first set up OSMC I did it on my Pi3 with the built-in WiFi and connected it to the netwok. Then I put the OSMC SD card in the Pi2 with the Edimax WiFi dongle and couldn’t get it to connect. I went back and forth a few (about 50) times trying to figure out why the WiFi worked on the Pi3 but not on the Pi2. I knew that the Edimax dongle worked just fine with Raspbian but wouldn’t work with OSMC. So in the process of getting logs for you I put the SD card in a different Pi3 and surprise the WiFi didn’t work. The WiFi configuration in OSMC is apparently specific to the actual WiFi device.
Best to avoid confirmation bias when working with a different system. Thanks for helping me get it running.
Connman saves the ssid/password in a file that includes the MAC address of the wifi dongle that ssid/password is assigned to.
So if you haven’t configured your ssid/password with a specific dongle it will not connect
