I’ve got a Pi2 that I want to use with OSMC. I’ve got two different WiFi dongles, an EDIMAX and a CanaKit, both work fine with Raspbian but neither work with OSMC. If I run the OSMC in my Pi3 the built-in WiFi works fine. Anybody got any ideas?
Unfortunately, a small snippet of information is often not enough.
Ideally, please post a full set of logs, either from the command line with grab-logs -A or via My OSMC -> Log Uploader -> All Configs and Logs. Then post the URL returned by either method.
In post #6 you say the Edimax dongle is using a Realtek RTL8188CUS chipset. The log is showing something a little different (though it might not be correct):
5V 2.5A? It works fine if I’m running Raspbian. I can understand if the power is minimal that maybe the WiFi dongle wouldn’t work but the power supply is adequate. There is nothing connected to the Pi2B except the dongle.
Anybody look at the logs I posted? Is there any information there that can point me in the right direction to make it work?
The real question is, even though the PSU states 5v/2.5A, does it actually maintain a 5v output while under a 2.5A load? This is not always easy to test and quite often, phone chargers and cheap foreign market PSUs cannot actually maintain that output. When the Pi is losing voltage due to an increased demand for amperage, shunting power from the USB bus to keep the processor and ram supplied is expected.
As you know, I did. I can tell you that the device is recognised, and the OS can see its MAC address and knows its on wlan0. But it doesn’t connect. I don’t think you’ve mentioned proximity to the router/access point so perhaps it’s simply too far away.
