I use a Raspberry Pi 2 with a USB WiFi dongle and after tonight’s update, I can’t connect to my wifi anymore.
Does anyone else have this problem?
Please boot with wifi adaptor connected, then use the Log uploader in My OSMC to upload your logs.
Do this either by temporarily connecting Ethernet before uploading the logs, or choose the option to save the logs locally. This will save a log file on the fat partition of the SD card, you can then shut down and put the SD card in your PC to open the log file and paste it to paste.osmc.io.
I changed my Edimax EW-7612UAn V2 with a TP-Link TL-WN823N and it works now.
The Edimax dongle works perfectly on my PC, but it won’t connect on my Raspberry anymore.
