Wifi Not Connecting
During install you set regional settings but not wifi settings. So I set regional settings and rebooted the Pi, then when it came back up I set the wifi. At that point I was able to connect to it, until I moved it from the room I was doing the setup in to the tv I wanted it connected to. Then wifi failed again. So I went into the wired settings and set the IP, then wifi connected and I was able to connect via the Kodi app as well as SSH into it. Hopefully it stays connected.
