I have a Edimax EW-7811UAC adapter. After July update all the problems with hung’s, stutters and dropouts ceased (finally) and all started to worked incredibly well.
I think that al was produced by the background scanning.
Unfortunately since august update all has started to happen again.
How can i disable or inspect if the scanning is working or whatever.
Thanks a lot.
Check /etc/connman.conf if you have BackgroundScanning = false in the [GENERAL] section
This is the content of /etc/conman.conf
[General]
PreferredTechnologies=ethernet,wifi
SingleConnectedTechnology=false
AllowHostnameUpdates=false
TetheringTechnologies=ethernet,wifi
PersistentTetheringMode=true
NetworkInterfaceBlacklist=vmnet,vboxnet,virbr,ifb,docker,veth
I will insert the line and try.
Thanks for your incredible fast response.
All is working perfectly again.
I have applied also September’s update.
Thaks a lot.
