so how can i set up wifi locale
and you pretty dum so you removed raspi-config and placed dummy message
dumb guys
Good Morning,
Not dumb, raspi-config hasn’t been removed. As OSMC is based on Debian, rather than RaspberryOS.
You can set region with:
sudo iw reg set GB for example
You can make permenant with crda, will probably need installing:
sudo apt-get update
sudo apt-get install crda
It will be added to My OSMC at a later date.
how? the command iw is not found
wtf
sudo apt-get install -y wireless-tools
Note: if you keep posting like an entitled arsehole when people are trying to help you, I will prohibit your ability to do so.
how can i do so without the internet?
You have a couple of options:
- Connect an Ethernet cable temporarily
- Change the channel temporarily on your router so you can connect and set the regulatory domain; then set it back.
We’ve only really see this cause issues in Germany with some users on channel 13.
i dont have ethernet
