Hello,
I recently bought Vero4k. I installed and configured all, and works great. Nice device!
I also installed raspotify (according this instructions: link)
Then I listened to music through that, stoped that, and let the device run. The next day the Wifi is not connected anymore. In the OSMC settings under network it does not show Wifi anymore. When I connect via cable and try things on the terminal I cannot find any reason for it.
dmes shows the following:
osmc@osmc:~$ dmesg | grep wifi
[ 0.253107] wifi: power_on_pin_OD = 0;
[ 0.253117] aml_wifi wifi.32: [wifi_dev_probe] no power_on_pin2
[ 0.253145] aml_wifi wifi.32: [pwm_double_channel_conf_dt] pwm phandle val=25;pwm-channel1=4;pwm-channel2=12
[ 0.253151] aml_wifi wifi.32: [pwm_double_channel_conf_dt] pwm_config1[0] = 30541
[ 0.253157] aml_wifi wifi.32: [pwm_double_channel_conf_dt] pwm_config2[0] = 30518
[ 0.253163] aml_wifi wifi.32: [pwm_double_channel_conf_dt] pwm_config1[1] = 15270
[ 0.253169] aml_wifi wifi.32: [pwm_double_channel_conf_dt] pwm_config2[1] = 15259
[ 0.253175] aml_wifi wifi.32: [pwm_double_channel_conf_dt] pwm_config1[2] = 6
[ 0.253180] aml_wifi wifi.32: [pwm_double_channel_conf_dt] pwm_config2[2] = 9
[ 0.253186] aml_wifi wifi.32: [pwm_double_channel_conf_dt] wifi pwm dt ok
[ 0.253205] aml_wifi wifi.32: [pwm_double_channel_conf] wifi pwm conf ok
[ 0.253245] aml_wifi wifi.32: [wifi_dev_probe] interrupt_pin=241
[ 0.253252] aml_wifi wifi.32: [wifi_dev_probe] irq_num=100, irq_trigger_type=1
[ 0.253258] aml_wifi wifi.32: [wifi_dev_probe] power_on_pin=240
[ 0.253263] aml_wifi wifi.32: [wifi_dev_probe] clock_32k_pin=0
[ 0.253381] aml_wifi wifi.32: [wifi_setup_dt] wifi_setup_dt
[ 0.253409] aml_wifi wifi.32: [wifi_setup_dt] interrupt_pin(241)
[ 0.253429] aml_wifi wifi.32: [wifi_setup_dt] power_on_pin(240)
[ 0.630189] efusekeyname: mac_wifi offset: 12 size: 6
[ 3.883042] aml_wifi wifi.32: [extern_wifi_set_enable] WIFI Disable! 240
[ 4.185830] aml_wifi wifi.32: [extern_wifi_set_enable] WIFI Enable! 240
connmanctl shows the following:
connmanctl> technologies
/net/connman/technology/ethernet
Name = Wired
Type = ethernet
Powered = True
Connected = True
Tethering = False
/net/connman/technology/bluetooth
Name = Bluetooth
Type = bluetooth
Powered = False
Connected = False
Tethering = False
connmanctl>
So I really wonder what is wrong here.
Thanks for the support
