Wifi with pmf enabled
Hello.
i’m trying to get my wifi net moved over to enable pmf but when i do so my osmc raspbery pi box gets kicked off the wifi network.
can someone enlighten me what the current state of pmf and wpa3 support is in osmc?
do i need to enable pmf support manually somehow?
I don’t know whether Pi 4 hardware supports protected management frames currently (which is a pre-req of WPA3).
You could check on Pi OS
