Hi there,
My WIFI dongle (which used to work on osmc RC2) is detecting network but fails to connect. Working fine on other devices. Here is my log file (I think!): http://paste.osmc.io/dexesubawa
Please help thank you.
Hi there,
Unfortunately if you click on the link you’ll see the log is empty. Please try again with uploading your logs.
Sorry. Try this: http://paste.osmc.io/robasahicu
Thanks. Andrew
Hi Andrew,
That is only a Kodi log - a Kodi log is not helpful for a wifi issue, we would need to see dmesg and the System journal. Thanks.
