Hello,
OSMC (on RPi3) asking only for password to WiFi. I have to also enter the username. How to do it?
PSK is different to Enterprise
I have the same problem. Is there a solution to it now?
hello Sam, could you please provide any manual method to connect to WPA2 Enterprise (802.11x authentication) wireless network. Pleaseā¦
You can do this manually via the command line with connmanctl
Thanks Sam, I will follow this lead
