Has there been any update to this? Anyone developed a keyboard mapping file?
In getting the same results:
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
osmc@osmc:~$ hostname
osmc
osmc@osmc:~$ ifconfig
eth0 Link encap:Ethernet HWaddr b8:27:eb:df:36:cd
inet addr:192.168.1.7 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST DYNAMIC MTU:1500 Metric:1
RX packets:48298 errors:0 dropped:0 overruns:0 frame:0
TX packets:25850 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:55561724 (52.9 MiB) TX bytes:2737124 (2.6 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:8 errors:0 dropped:0 overruns:0 frame:0
TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:400 (400.0 B) TX bytes:400 (400.0 B)
osmc@osmc:~$ irw
^C
osmc@osmc:~$ tail -f /home/osmc/.kodi/temp/kodi.log
21:34:59.842 T:1958555648 NOTICE: VideoPlayer: waiting for threads to exit21:34:59.842 T:1958555648 NOTICE: VideoPlayer: finished waiting 21:34:59.842 T:1958555648 NOTICE: CVideoPlayer::CloseFile() 21:34:59.842 T:1958555648 NOTICE: VideoPlayer: waiting for threads to exit21:34:59.842 T:1958555648 NOTICE: VideoPlayer: finished waiting 21:41:49.196 T:1958555648 ERROR: Control 50 in window 10025 has been asked to focus, but it can’t 21:41:59.298 T:1187910640 NOTICE: URLResolver: Initializing URLResolver version: 4.0.12
21:42:12.697 T:1958555648 ERROR: GetDirectory - Error getting plugin://plugin.video.covenant/?action=addItem&title=Coco
21:42:12.699 T:1958555648 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.covenant/?action=addItem&title=Coco) failed
21:42:14.660 T:1311638512 NOTICE: URLResolver: Initializing URLResolver version: 4.0.12
21:50:57.783 T:1958555648 WARNING: Cleanup: Having to cleanup texture button-nofocus.png
21:50:57.785 T:1958555648 WARNING: Cleanup: Having to cleanup texture button-focus.png
21:50:58.834 T:1751118832 WARNING: CSkinInfo: failed to load skin settings
21:52:51.793 T:1958555648 NOTICE: Log level changed to “LOG_LEVEL_DEBUG_FREEMEM”
21:52:51.794 T:1958555648 NOTICE: Enabled debug logging due to GUI setting. Level 2.
21:52:51.796 T:1958555648 DEBUG: ------ Window Init () ------
21:52:54.943 T:1958555648 DEBUG: ProcessMouse: trying mouse action rightclick
21:52:54.971 T:1958555648 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
21:52:54.971 T:1958555648 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
21:52:54.973 T:1958555648 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
21:52:54.973 T:1958555648 DEBUG: ------ Window Init (Settings.xml) ------21:53:00.928 T:1958555648 DEBUG: ------ Window Deinit (Pointer.xml) ------
21:53:02.028 T:1958555648 DEBUG: Keyboard: scancode: 0x6a, sym: 0x0113, unicode: 0x0000, modifier: 0x0
21:53:02.028 T:1958555648 DEBUG: OnKey: right (0xf083) pressed, action is Right
21:53:02.202 T:1958555648 DEBUG: Keyboard: scancode: 0x6a, sym: 0x0113, unicode: 0x0000, modifier: 0x0
21:53:03.720 T:1958555648 DEBUG: Keyboard: scancode: 0x69, sym: 0x0114, unicode: 0x0000, modifier: 0x0
21:53:03.720 T:1958555648 DEBUG: OnKey: left (0xf082) pressed, action is Left
21:53:03.721 T:1918890992 INFO: CActiveAESink::OpenSink - initialize sink
21:53:03.722 T:1918890992 DEBUG: CActiveAESink::OpenSink - trying to open device PI:HDMI
21:53:03.722 T:1918890992 DEBUG: CAESinkPi:Initialize Format:15 Channels:2 Samplerate:44100 framesize:8 bufsize:17640 bytes/s=352800.00 dest=PI:HDMI21:53:03.723 T:1918890992 DEBUG: CAESinkPi:SetAudioProps hdmi_stream_channels 0 hdmi_channel_map 00000008
21:53:03.725 T:1918890992 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_render input port 100 output port 100 m_handle 0x65a0e320
21:53:03.728 T:1918890992 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.audio_render) - port(100), nBufferCountMin(1), nBufferCountActual(2), nBufferSize(17648), nBufferAlignmen(16)
21:53:03.729 T:1918890992 DEBUG: CActiveAESink::OpenSink - SinkPi Initialized:
21:53:03.730 T:1918890992 DEBUG: Output Device : HDMI
21:53:03.730 T:1918890992 DEBUG: Sample Rate : 44100
21:53:03.730 T:1918890992 DEBUG: Sample Format : AE_FMT_FLOAT
21:53:03.731 T:1918890992 DEBUG: Channel Count : 2
21:53:03.731 T:1918890992 DEBUG: Channel Layout: FL,FR
21:53:03.731 T:1918890992 DEBUG: Frames : 2205
21:53:03.732 T:1918890992 DEBUG: Frame Size : 8
21:53:03.891 T:1958555648 DEBUG: Keyboard: scancode: 0x69, sym: 0x0114, unicode: 0x0000, modifier: 0x0
21:53:05.119 T:1958555648 DEBUG: Previous line repeats 1 times.
21:53:05.119 T:1958555648 DEBUG: OnKey: left (0xf082) pressed, action is Left
21:53:05.372 T:1958555648 DEBUG: Keyboard: scancode: 0x69, sym: 0x0114, unicode: 0x0000, modifier: 0x0
21:53:09.522 T:1958555648 DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0
21:53:09.522 T:1958555648 DEBUG: OnKey: down (0xf081) pressed, action is Down
21:53:09.693 T:1958555648 DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0
21:53:11.327 T:1958555648 DEBUG: Keyboard: scancode: 0x67, sym: 0x0111, unicode: 0x0000, modifier: 0x0
21:53:11.328 T:1958555648 DEBUG: OnKey: up (0xf080) pressed, action is Up21:53:11.587 T:1958555648 DEBUG: Keyboard: scancode: 0x67, sym: 0x0111, unicode: 0x0000, modifier: 0x0
21:53:12.360 T:1958555648 DEBUG: Keyboard: scancode: 0x69, sym: 0x0114, unicode: 0x0000, modifier: 0x0
21:53:12.361 T:1958555648 DEBUG: OnKey: left (0xf082) pressed, action is Left
21:53:12.653 T:1958555648 DEBUG: Keyboard: scancode: 0x69, sym: 0x0114, unicode: 0x0000, modifier: 0x0
21:53:14.095 T:1958555648 DEBUG: CLinuxInputDevice::KeyEvent: TranslateKey returned XBMCK_UNKNOWN from code(412)
21:53:16.801 T:1759507440 DEBUG: Previous line repeats 1 times.
21:53:16.801 T:1759507440 DEBUG: script.module.osmcsetting.updates : - blurp 937 - Settings.xml
21:53:19.152 T:1958555648 DEBUG: CLinuxInputDevice::KeyEvent: TranslateKey returned XBMCK_UNKNOWN from code(407)
21:53:24.277 T:1958555648 DEBUG: Previous line repeats 1 times.
21:53:24.277 T:1958555648 DEBUG: CLinuxInputDevice::KeyEvent: TranslateKey returned XBMCK_UNKNOWN from code(257)
21:53:25.068 T:1958555648 DEBUG: Previous line repeats 1 times.
21:53:25.069 T:1958555648 DEBUG: CLinuxInputDevice::KeyEvent: TranslateKey returned XBMCK_UNKNOWN from code(258)
21:53:26.276 T:1958555648 DEBUG: Previous line repeats 1 times.
21:53:26.277 T:1958555648 DEBUG: CLinuxInputDevice::KeyEvent: TranslateKey returned XBMCK_UNKNOWN from code(316)
21:53:27.112 T:1958555648 DEBUG: Previous line repeats 1 times.
21:53:27.112 T:1958555648 DEBUG: CLinuxInputDevice::KeyEvent: TranslateKey returned XBMCK_UNKNOWN from code(305)
21:53:28.228 T:1958555648 DEBUG: Previous line repeats 1 times.
21:53:28.228 T:1958555648 DEBUG: CLinuxInputDevice::KeyEvent: TranslateKey returned XBMCK_UNKNOWN from code(304)
21:53:36.295 T:1958555648 DEBUG: Previous line repeats 1 times.
21:53:36.295 T:1958555648 DEBUG: Keyboard: scancode: 0x69, sym: 0x0114, unicode: 0x0000, modifier: 0x0
21:53:36.295 T:1958555648 DEBUG: OnKey: left (0xf082) pressed, action is Left
21:53:36.464 T:1958555648 DEBUG: Keyboard: scancode: 0x69, sym: 0x0114, unicode: 0x0000, modifier: 0x0
21:53:36.995 T:1958555648 DEBUG: Keyboard: scancode: 0x6a, sym: 0x0113, unicode: 0x0000, modifier: 0x0
21:53:36.996 T:1958555648 DEBUG: OnKey: right (0xf083) pressed, action is Right
21:53:37.126 T:1958555648 DEBUG: Keyboard: scancode: 0x6a, sym: 0x0113, unicode: 0x0000, modifier: 0x0
21:53:37.787 T:1958555648 DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0
21:53:37.787 T:1958555648 DEBUG: OnKey: down (0xf081) pressed, action is Down
21:53:37.911 T:1958555648 DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0
21:53:38.878 T:1958555648 DEBUG: CLinuxInputDevice::KeyEvent: TranslateKey returned XBMCK_UNKNOWN from code(304)
21:53:39.387 T:1958555648 DEBUG: Previous line repeats 1 times.
21:53:39.388 T:1958555648 DEBUG: CLinuxInputDevice::KeyEvent: TranslateKey returned XBMCK_UNKNOWN from code(412)
21:53:39.962 T:1958555648 DEBUG: Previous line repeats 1 times.
21:53:39.963 T:1958555648 DEBUG: CLinuxInputDevice::KeyEvent: TranslateKey returned XBMCK_UNKNOWN from code(316)
21:53:40.504 T:1958555648 DEBUG: Previous line repeats 1 times.
21:53:40.505 T:1958555648 DEBUG: CLinuxInputDevice::KeyEvent: TranslateKey returned XBMCK_UNKNOWN from code(407)
21:53:41.202 T:1958555648 DEBUG: Previous line repeats 1 times.
21:53:41.203 T:1958555648 DEBUG: CLinuxInputDevice::KeyEvent: TranslateKey returned XBMCK_UNKNOWN from code(257)
21:53:41.624 T:1958555648 DEBUG: Previous line repeats 1 times.
21:53:41.625 T:1958555648 DEBUG: CLinuxInputDevice::KeyEvent: TranslateKey returned XBMCK_UNKNOWN from code(258)
21:53:42.252 T:1958555648 DEBUG: Previous line repeats 1 times.
21:53:42.253 T:1958555648 DEBUG: CLinuxInputDevice::KeyEvent: TranslateKey returned XBMCK_UNKNOWN from code(305)
