How / Where to download ?
I read it as RC today and Final on 5th March
Download is expected to be available 8pm GMT.
I would assume it will be available through the installer or directly from diskimages directory.
As for the Mar 5 date, Sam announced earlier in this thread that todayâs release will be a Release Candidate as opposed to a final release.
Plan to do a fresh install with tonightâs release and you should be able to just upgrade to the final when itâs ready.
Hi guys,
Just to clarify: there is no upgrade path from A4 to the RC. We want to put out an RC first to test everything works and create a migration path to the final version for our users.
I am just waiting for Jenkins to build everything and as soon as thatâs done and basic testing is done and verified working weâll ship a release candidate
The 5th March date is just a place holder
Hi Sam,
Is this a ThunderâŚwhooooosh?
So does that mean the RC will be up soon (within hours?) or in day or so? Trying to plan out my afternoon
Will we be able use the our already downloaded installer? Or will we have to download another one?
Thanks for all the hard work!
-Steve
The installer will be fine, it automatically retreives the latest versions from the download server when you open it. Iâve fixed a couple of visual things though, so you might want to update it, but it wonât affect install.
Not 100% sure yet, but donât want to make any false promises.
The âfalse promiseâ has been done - for GMT 8:00 pm tonight, now called âplaceholderââŚ
Hello, Sam. Without âmaking any promisesâ can you explain what you mean by âthere is no upgrade âPATHâ from A4 to the RCâ? I guess I am asking what method are you using to deploy the upgrade. Pardon my inability to make the sentence i want here⌠um⌠OK will there be an apt-get update line code way of moving from the A4 to the RC1, for example? So us end-users can just tarball up or .kodi folders and copy them?
Or will we need to do that and then format the microSD? Or is this what you are trying to decide? For us âend-usersâ that would like to do this the OSMC-Team recommended way, but not go through microSD removal, Windows/OSX formatting and re-imaging with the installer (unless we have to)⌠Have you decided how to deploy the RC on a community this size? Ok i wrote too much maybe you know what i mean and can tell us when you know. Also, i have read 8am, 8pm⌠what timezone would that be? its well past 8am in Chicago, IL so i guess thatâs 8pm, but youâre out in the UK right? I thought there would be a countdown timer on the thunderclap page⌠i know about five people that are on the edges of their seats waiting and i told them that i would ask.
OK well sorry i am so wordyâhope that you are picking up what i am puttinâ down. If not just say what? I get that sometimes.
You can tarball .kodi and copy it over and tar -xzf it. But there is no apt-get dist-upgrade path for Alphas to Release Candidate / Final. From RC onwards you will be able to update using the OSMC Updater.
You have to remove and re-image Iâm afraid. We did say that the Alphas wouldnât necessarily have an upgrade path to final.
We are waiting on Jenkins: http://jenkins.osmc.tv to get everything built. I am in the UK GMT. Those times are just placeholders. I will announce it on osmc.tv when itâs ready
S
Sam: Wow, you type fast. And you answered like every question i âtarâdâ into that paragraph. Well then my next question is are all the installers âworkingâ because i use a Mac but i read a post that said (for one guy) that the OSX installer just âHung & loopedâ so what would you recommend i use the Windows installer? Or is the OSX installer fixed? I have access to a windows machine⌠should i just use that to be safe?
Thanks for any advice and all your answers.
Marc
Our installers are testing and have been tested. There was a bug a while back where OS X did not play so nice if the userâs home directory had a space in it (i.e. FirstName LastName), but Iâve taken care of that. Just make sure you download the latest build from Download - OSMC. Donât worry about doing it before the announcement: the installer automatically fetches the latest builds from the server when it opens so you donât really need to update the installer much if itâs working (only when we release a new device)
S
So the installers have version #s? Cool what is the current OSX installer version? And the OSMC available âbuilds-listâ in the drop-down list is âfetchedâ from the internet, you say, so once an installer is working we can just use the same one⌠very cool. It keeps getting easier
If i used the Windows installer for Alpha4 on a fresh-out-the-box microSD (RPi2), can i switch and do them with the OSX installer going forward from here? (The microSD goes into a 'normal SDHC adapter, that goes into the SD to USB adapter) and it worked fine on Windows⌠Mac always has little surprises, especially on older macbooks (mine is from 2008 and on Snow Leopard⌠the app store wasnât a part of OSX till 10.6.8, just FYI).
OK thanks again for the YEAR of work you and your team have done⌠we are all super grateful !
I have a question on installing the OSX installer, but i think iâll start a new topic it is a bit âoff subjectâ for in here.
Thanks for the insights and answers!
The âOSMC Updaterâ you refer to is (if using the Confluence skin) located in "Programs, OSMC Settings 0.0.1, UPDATES, then MANUAL CONTROLS, Scan for Updates Now, (wait for the packages to download) then under MANUAL CONTROLS again click âInstall available updates nowâ, right? (I donât see anything called the âOSMC Updaterâ verbatim. BUT that canât be done till getting up to the RC level using the Installer(s), correct?
and
Everyone has to use an installer to go from Alpha4 to RC, correct?
(Thanks, i have a question on installing the OSX installer but iâll start a topic for that⌠the .dmg is different than i am used too.)
@marc, Seeing as you have many questions, and this topic has kinda gone off on a tangent, i think it would be sensible to start a new topic.
Just to keep things nice and tidy.
Really looking forward to the release and have been watching the build page like a hawk.
So much want!
Yeah i moved my questions to https://discourse.osmc.tv/t/mac-osx-installer sorry bud.
