Hey guys, I have a large collection of Mp3 files and I’m looking for an app to play them with. If you remember Winamp on the PC you could easily search your library, select an album or artist and queue them up to play.
Is there such a thing I can install on to my Vero 4k+?
Simple instructions please, i’m very new to this device and almost 0 experience with linux systems.
I think global search is actually installed by default. Regardless, I think for music Kodi’s search is a bit better as it doesn’t take you to a different interface. When you are in the music section there is a search option in the slideout menu. How you bring up the slideout menu depends on the skin but normally it is a matter of going all the way left or up. With the Vero remote holding the menu button down should also allow bring it up.
As for queuing items you just have to context menu (menu button on the Vero remote) over an item and you will see the option. Kodi also allows for the generation of smart playlists.
