Wired connection stopped working after upgrade
I believe the root cause is I removed the lease from my DHCP server, once recreating it won’t take the new one. I had the same issue on one of my servers running debian. I ran dhclient -r and it was resolved. does ConnMan have an equivalent to drop it’s current lease?
Completely delete the service from /var/lib/connman
You’ll need CLI access however.
no problem, do I need to do anything after that? or will it reinstall on reboot?
If you delete the service file only (not the directory), it will restore itself.
https://0bin.net/paste/pj1eYJeUz2ok6ZjU#O9gGcnDLp-mz7s3lkx1PBuzFl1byeX8eaTiR7THcuuN
I’m not quite clear what to remove, can you please clarify?
Please use the OSMC pastebin in future
but
-rw------- 1 root root 4096 Oct 22 19:27 ./ethernet_c44eac0aaf3b_cable/data
-rw------- 1 root root  150 Oct 22 19:27 ./ethernet_c44eac0aaf3b_cable/settings
can be ripped
I am getting Networking Add-On unhandled exception caught - see log for details popups,
what is the location of that log?
It will be put in the Kodi log.
At this point I’d suggest reinstalling OSMC. Something seems borked.
@fzinken brings this to my attention:
Oct 22 16:02:37 osmc kernel: rx stop, recover eth
Oct 22 16:02:37 osmc connmand[384]: eth0 {RX} 0 packets 0 bytes
Oct 22 16:02:37 osmc connmand[384]: eth0 {TX} 102 packets 4777 bytes
Can you try updating to staging over WiFi?
  1. Login via the command line
  2. Edit the file /etc/apt/sources.list
  3. Add the following line: deb http://apt.osmc.tv jessie-devel main
  4. Run the following commands to update: sudo apt-get update && sudo apt-get dist-upgrade && reboot
  5. Your system should have have received the update.
that worked after a few tries enabling the interface. thanks a lot @sam_nazarko and @fzinken!!
