First, congratulations on the new 2021.08-1 release!
I expected a few bumps after upgrade, and negotiated some minor issues already.
But I’m stuck on what appears to be a regression in the 4.9 kernel on a Vero4K device:
root@vero4k:/# e2fsck -fv /dev/storage/array1
e2fsck 1.44.5 (15-Dec-2018)
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
21474 inodes used (0.00%, out of 732553216)
4936 non-contiguous files (23.0%)
52 non-contiguous directories (0.2%)
# of inodes with ind/dind/tind blocks: 0/0/0
Extent depth histogram: 16622/4822/21
2365900915 blocks used (40.37%, out of 5860419584)
0 bad blocks
1503 large files
19695 regular files
1769 directories
0 character device files
0 block device files
0 fifos
0 links
1 symbolic link (1 fast symbolic link)
0 sockets
21465 files
root@vero4k:/# mount -t ext4 /dev/storage/array1 /mnt/storage
mount: /mnt/storage: mount(2) system call failed: Structure needs cleaning.
The block device is an LVM logical volume with an ext4 filesystem backed by a software-controlled RAID-5 array. Note, the filesystem is over 20TB and requires a 64-bit kernel to handle correctly.
All of my web searching thus far for “Structure needs cleaning” suggests filesystem corruption, but as best as I can tell the filesystem is clean (as shown above) and the RAID array is working nominally (as shown below).
No problems mounting with the 3.14 kernel, but the 4.9 kernel just won’t do it.
I installed debug packages and traced /bin/mount to the mount(2) syscall just to verify the error message is indeed coming from the 4.9 kernel, but I’m a novice at kernel debugging so the trail has gone cold for me.
Here’s more storage details:
root@vero4k:/# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 7.3T 0 disk
└─sda1 8:1 0 7.3T 0 part
└─md127 9:127 0 21.9T 0 raid5
└─storage-array1 254:1 0 21.9T 0 lvm
sdb 8:16 0 7.3T 0 disk
└─sdb1 8:17 0 7.3T 0 part
sdc 8:32 0 7.3T 0 disk
└─sdc1 8:33 0 7.3T 0 part
sdd 8:48 0 7.3T 0 disk
└─sdd1 8:49 0 7.3T 0 part
mmcblk0 179:0 0 14.6G 0 disk
mmcblk0boot0 179:32 0 4M 0 disk
mmcblk0boot1 179:64 0 4M 0 disk
mmcblk0rpmb 179:96 0 4M 0 disk
root@vero4k:/# lvdisplay storage
--- Logical volume ---
LV Path /dev/storage/array1
LV Name array1
VG Name storage
LV UUID xIkqFS-miW4-XYuw-RPU4-gELx-Qm3e-D9jq5U
LV Write Access read/write
LV Creation host, time osmc, 2020-01-27 13:49:39 -0500
LV Status available
# open 0
LV Size 21.83 TiB
Current LE 5723066
Segments 1
Allocation inherit
Read ahead sectors auto
- currently set to 6144
Block device 254:1
root@vero4k:/# vgdisplay storage
--- Volume group ---
VG Name storage
System ID
Format lvm2
Metadata Areas 1
Metadata Sequence No 5
VG Access read/write
VG Status resizable
MAX LV 0
Cur LV 1
Open LV 0
Max PV 0
Cur PV 1
Act PV 1
VG Size 21.83 TiB
PE Size 4.00 MiB
Total PE 5723066
Alloc PE / Size 5723066 / 21.83 TiB
Free PE / Size 0 / 0
VG UUID NJxjXk-XXNS-u3RW-Ra0b-CgjS-eqHZ-g8CeKn
root@vero4k:/# pvdisplay /dev/md127
Error reading device /dev/mmcblk0rpmb at 0 length 512.
Error reading device /dev/mmcblk0rpmb at 0 length 4096.
--- Physical volume ---
PV Name /dev/md127
VG Name storage
PV Size 21.83 TiB / not usable 1.00 MiB
Allocatable yes (but full)
PE Size 4.00 MiB
Total PE 5723066
Free PE 0
Allocated PE 5723066
PV UUID 998TFi-Jugd-TupT-sYdz-E4eo-Y7eE-I1ws32
root@vero4k:/# mdadm --detail /dev/md127
/dev/md127:
Version : 1.2
Creation Time : Sat Jan 18 15:31:11 2020
Raid Level : raid5
Array Size : 23441679360 (22355.73 GiB 24004.28 GB)
Used Dev Size : 7813893120 (7451.91 GiB 8001.43 GB)
Raid Devices : 4
Total Devices : 4
Persistence : Superblock is persistent
Intent Bitmap : Internal
Update Time : Mon Aug 9 21:23:28 2021
State : clean
Active Devices : 4
Working Devices : 4
Failed Devices : 0
Spare Devices : 0
Layout : left-symmetric
Chunk Size : 512K
Consistency Policy : unknown
UUID : fb3dd008:ad989aa9:bd93cb0c:2f0f242c
Events : 992601
Number Major Minor RaidDevice State
0 8 1 0 active sync /dev/sda1
1 8 33 1 active sync /dev/sdc1
3 8 49 2 active sync /dev/sdd1
4 8 17 3 active sync /dev/sdb1
