Good morning , first of all I want to congratulate you for the great work they do !! .
For some time ago I use OSMC, but I could not play X265 ( HEVC ) 720p RPI2 without frostbite. These same files OpenELEC ( Milhouse Build ) no problem , but from what I understand have made some kind of optimization . Someday we can play without problems in OSMC?.
Thank you!.
The patches for GPU HEVC accel don’t compile properly under Debian GCC. I have mentioned this to @popcornmix, and for now, our focus is on getting Jarvis to build properly and to get it out the door on time.
I’ll revisit it shortly post-release
Sam excellent !!! Thank you very much for your great work !.
Regards.
The patches are now added without issue and will be included in the Jarvis build
Thanks Sam:grinning:
Amazing, Sam !!! . Again, thank you for the great work they do , it really is great !!! .
Does this mean rpi2 will be able to play hevc x265 in the jarvis build?
I thought the rpi2 wasnt powerful for this.
Be awesome if it works
It means it will play low bitrate 720p HEVC content. Don’t expect too much from this for now
