X265 HEVC Glitches after seeking
I have noticed that with HEVC x265 content, the Vero 4K plays fine, but if I was to hit the Fwd button, the playback starts glitching (best way I can define it). I typically play via an NFS mount, but to rule out the network, I have tried playing back via a USB drive directly with the same results.
If you want a sample, try any ‘megusta’ encoded files.
Uploaded as instructed via My OSMC
http://paste.osmc.tv/cebaxamava
There are discontinuities, which cause this issue.
This is likely because of your settings.
You should set the GUI to 1080p and enable Adjust Refresh Rate.
It should then work properly.
Gave it a go. Set the display resolution to 1080p.
Video settings to adjust refresh rates all the time.
Replayed the same file, and the ‘glitch’ is still there. Just to explain, sound and playback still paying. Every few seconds the image on screen flickers briefly, the resumes and happens again.
Logs after changes at: https://paste.osmc.tv/dizanohali
I’ll check this out tomorrow.
Can you upload a sample file to https://videosam.pl?
Sorry - hard to provide a sample. But some I know of having trouble are some of the Megusta releases (megusta hevc x265).
We aren’t going to pirate material to test. Additionally, if the issue is only present in some random pirate’s rips, it’s more likely that the issue is due to his encode method and not an OSMC issue.
If you wish to have the issue looked at, use something like mkvtoolnix to create a small sample file that demonstrates the issue.
