Does anyone know how to get this remote to work with OSMC.?
I’ve got an RC6 remote working but would love to use this one…
I’m pretty sure it’s just another RC6 remote
I have an RC6 remote that works with my current setup… This remote doesn’t work, It’s definitely sending out a signal as i’ve programed my TV code into it and it’s controlling my TV/AVR.
Is that a Microsoft remote or some aftermarket?
You can always learn it
The RC6 remote I have is an aftermarket one… The one I’m trying to use is a Microsoft one…
How do I learn it.?
OSMC Forums Step 3 Change any path etc with “pi” in it to “osmc”
Once you have created the .conf file go to MyOSMC remote module and browse to it
I think you’ll find that it’s very close to the RC6 supplied, maybe some differences in the remote signal definition area. These remotes are the same as the MCE remote, they just have the remote ID changed so they can co exist with a MCE PC in the same room.
There is a button sequence on the remote that will change the remote ID, can’t remember what it is though.
Sorry I may not have been clear. My thoughts are all that will be different are the remote header, you can learn just a few buttons and then compare to the existing RC6 conf file, if button codes are the same but headers have changed then you can use the existing button codes rather than learning all the buttons
Thanks Dilligaf,
Although that tutorial is a bit beyond my skill set…
It’s really not hard if you can ssh.
If you could capture a few keys I would like to have a look at it and try to figure it out
Try this,copy/paste it into a text file named Xbox360-lircd.conf save it to somewhere on your Pi then browse to it in the remote module and select it
# this config file was automatically generated
# using lirc-0.8.0-CVS(mceusb2) on Tue Jan 17 15:14:11 2006
# contributed by Kyle at shadowmage.org
# brand: Microsoft
# model no. of remote control: Xbox 360 Universal Media Remote
# devices being controlled by this remote: Xbox 360
# This probably works for the normal Xbox 360 remote too.
# TV button sends no signal and toggles Xbox 360/TV mode. TV mode can be
# signals for any device the remote supports. Volume Up, Volume Down and
# Mute always use the TV mode while the Xbox live guide button always sends
# to the xbox.
begin remote
name Microsoft_Xbox360
bits 16
flags RC6|CONST_LENGTH
eps 30
aeps 100
header 2676 870
one 454 429
zero 454 429
pre_data_bits 21
pre_data 0x37FF0
gap 106291
min_repeat 1
toggle_bit_mask 0x8000
rc6_mask 0x100000000
begin codes
KEY_OPEN 0x8BD7 # Was: OpenClose
XboxFancyButton 0x0B9B
KEY_POWER 0x8BF3 # Was: OnOff
KEY_STOP 0x0BE6 # Was: Stop
KEY_PAUSE 0x8BE7 # Was: Pause
KEY_REWIND 0x0BEA # Was: Rewind
KEY_FASTFORWARD 0x8BEB # Was: FastForward
KEY_PREVIOUS 0x0BE4 # Was: Prev
KEY_NEXT 0x8BE5 # Was: Next
KEY_PLAY 0x0BE9 # Was: Play
Display 0x8BB0
KEY_TITLE 0x0BAE # Was: Title
KEY_MENU 0x8BDB # Was: DVD_Menu
KEY_BACK 0x0BDC # Was: Back
KEY_INFO 0x8BF0 # Was: Info
UpArrow 0x0BE1
LeftArrow 0x8BDF
RightArrow 0x0BDE
DownArrow 0x8BE0
KEY_OK 0x0BDD # Was: OK
KEY_Y 0x8BD9 # Was: Y
KEY_X 0x0B97 # Was: X
KEY_A 0x8B99 # Was: A
KEY_B 0x0BDA # Was: B
KEY_CHANNELUP 0x8BED # Was: ChUp
KEY_CHANNELDOWN 0x0BEC # Was: ChDown
KEY_VOLUMEDOWN 0x0BEE # Was: VolDown
KEY_VOLUMEUP 0x0BEF # Was: VolUp
KEY_MUTE 0x0BF1 # Was: Mute
KEY_PLAY 0x0BF2 # Was: Start
KEY_PLAY 0x8BE9 # Was: Play
KEY_ENTER 0x0BF4 # Was: Enter
KEY_RECORD 0x8BE8 # Was: Record
KEY_CLEAR 0x0BF5 # Was: Clear
KEY_1 0x8BFE # Was: 1
KEY_2 0x0BFD # Was: 2
KEY_3 0x8BFC # Was: 3
KEY_4 0x0BFB # Was: 4
KEY_5 0x8BFA # Was: 5
KEY_6 0x0BF9 # Was: 6
KEY_7 0x8BF8 # Was: 7
KEY_8 0x0BF7 # Was: 8
KEY_9 0x8BF6 # Was: 9
KEY_0 0x0BE2 # Was: 100
KEY_0 0x8BFF # Was: 0
Reload 0x8BE3
end codes
end remote
That didn’t work but i had a google around and found this one that did work :o) :
# Please make this file available to others
# by sending it to <lirc@bartelmus.de>
# using lirc-0.9.0-pre1(default) on Fri Feb 22 12:48:57 2013
# contributed by
# brand: /home/pi/lircd.conf.conf
begin remote
name /home/pi/lircd.conf.conf
bits 13
eps 30
aeps 100
header 2706 847
one 475 411
zero 475 411
pre_data_bits 24
pre_data 0x1BFF80
gap 107073
min_repeat 2
# suppress_repeat 2
# uncomment to suppress unwanted repeats
begin codes
KEY_POWER 0x0BF3
KEY_HOME 0x0B9B
KEY_YELLOW 0x0BD9
KEY_BLUE 0x0B97
KEY_GREEN 0x0B99
KEY_RED 0x0BDA
KEY_REWIND 0x0BEA
KEY_PLAYPAUSE 0x0BE7
KEY_FASTFORWARD 0x0BEB
KEY_BACK 0x0BE4
KEY_MENU 0x0BDB
KEY_NEXT 0x0BE5
KEY_STOP 0x0BE8
KEY_INFO 0x0BF0
KEY_UP 0x0BE1
KEY_LEFT 0x0BDF
KEY_RIGHT 0x0BDE
KEY_OK 0x0BDD
KEY_DOWN 0x0BE0
KEY_BACK 0x0BDC
end codes
end remote
Do you know if it’s possible to cut/past from your one into the 2nd one to make a more comprehensive file with more of the buttons covered.?
The codes look the same to me.?
OK, so that file you posted works the 360, correct?
now copy/paste this to the top of the file overwriting what’s there[code]
bits 13
eps 30
aeps 100
header 2674 870
one 455 427
zero 455 427
pre_data_bits 24
pre_data 0x1BFF82
gap 106288
min_repeat 1
[/code]
This should now (hopefully) work with a MCE remote, if it does edit the file and change pre_data 0x1BFF82
to this
pre_data 0x1BFF80
If all goes as expected the 360 remote should now work.
I think the pre_data is the key, let me know what happens
I use that remote for all 4 of my installs. I don’t know where I originally found the lirc.conf but I have pasted my current working one here. All of the buttons have function including the Xbox button at the top for the context menu. I have been playing around with the remote for the Xbox One as well so you will see code at the bottom for that. I never did clean any of the file so it looks a mess but at least it gives credit to whom ever I got it from.
# /etc/lirc/lircd.conf.rpi
# Lirc config for lirc_rpi (GPIO) receiver.
# Enables use of MCE Remote, Apple MacMini and XBOX remote.
# Should work with any generic receiver
# contributed by jenkins101
# brand: HP/Philips/Microsoft/Other
# model no. of remote control: Media Center Edition remote
# devices being controlled by this remote: myriad of devices with Media Center Edition receivers
# RC-6 config file
# source: http://home.hccnet.nl/m.majoor/projects_remote_control.htm
# http://home.hccnet.nl/m.majoor/pronto.pdf
# used by: Philips
# Philips Media Center Edition remote control
# For use with the USB MCE ir receiver
# Dan Conti dconti|acm.wwu.edu
# Updated with codes for MCE 2005 Remote additional buttons
# *, #, Teletext, Red, Green, Yellow & Blue Buttons
# Note: TV power button transmits no code until programmed.
# Updated 12th September 2005
# Graham Auld - mce|graham.auld.me.uk
# Radio, Print, RecTV are only available on the HP Media Center remote control
# Updated with codes for MCE 2007 Remote additional buttons
# Visualization, Aspect, SlideShow, Eject
# Note:
# Blue, Yellow, Green, Red, and Teletext buttons do not exist on some HP remote
# using lirc-0.9.0-pre1(default) on Sat Feb 23 12:47:57 2013
# contributed by DynaMight
# brand: Xbox 360 remote
begin remote
name Xbox 360 Remote
bits 13
eps 30
aeps 100
header 2685 886
one 457 433
zero 457 433
pre_data_bits 24
pre_data 0x1BFF80
gap 107197
min_repeat 4
suppress_repeat 99
begin codes
KEY_STOP 0x0BE6
KEY_PLAY 0x0BE9
KEY_VOLUMEUP 0x0BEF
KEY_MUTE 0x0BF1
KEY_0 0x0BFF
KEY_1 0x0BFE
KEY_2 0x0BFD
KEY_3 0x0BFC
KEY_4 0x0BFB
KEY_5 0x0BFA
KEY_6 0x0BF9
KEY_7 0x0BF8
KEY_8 0x0BF7
KEY_9 0x0BF6
KEY_MENU 0x0BDB
KEY_YELLOW 0x0BD9
KEY_BLUE 0x0B97
KEY_GREEN 0x0B99
KEY_RED 0x0BDA
KEY_REWIND 0x0BEA
KEY_PLAYPAUSE 0x0BE9
KEY_EXIT 0x0BDC
KEY_TITLE 0x0B9B
KEY_STOP 0x0BE6
KEY_INFO 0x0BF0
KEY_UP 0x0BE1
KEY_DOWN 0x0BE0
KEY_LEFT 0x0BDF
KEY_RIGHT 0x0BDE
KEY_OK 0x0BDD
KEY_CONTEXT_MENU 0x0BF3
KEY_PAGEUP 0x0B93
KEY_PAGEDOWN 0x0B92
KEY_ENTER 0x0BF4
KEY_STOP 0x0BE8
KEY_CLEAR 0x0BF5
KEY_NEXTSONG 0x0BE5
KEY_PREVIOUSSONG 0x0BE4
KEY_DISPLAYTOGGLE 0x0BB0
KEY_PAUSE 0x037FF00BE7
end codes
end remote
# Please make this file available to others by sending it to <lirc@bartelmus.de>
# this config file was automatically generated using lirc-0.9.0(default) on Wed Mar 26 17:55:18
# 2014
# contributed by FishOil
# brand: XBOX-ONE model no. of remote control: XBOX ONE Media Remote devices being controlled by
# this remote: XBMC XBOX ONE
begin remote
name XBOX-ONE
bits 16
flags SPACE_ENC|CONST_LENGTH
eps 30
aeps 100
header 9061 4460
one 596 1662
zero 596 527
ptrail 582
repeat 9032 2232
pre_data_bits 16
pre_data 0x11B
gap 107260
toggle_bit_mask 0x0
begin codes
KEY_MENU 0x26D9
KEY_TITLE 0x7689
KEY_MENU 0xF609
KEY_UP 0x7887
KEY_DOWN 0xF807
KEY_LEFT 0x04FB
KEY_RIGHT 0x847B
KEY_OK 0x44BB
KEY_BACK 0xC43B
KEY_INFO 0x649B
KEY_VOLUMEUP 0x08F7
KEY_VOLUMEDOWN 0x8877
KEY_MUTE 0x708F
KEY_PAGEUP 0x48B7
KEY_PAGEDOWN 0xC837
KEY_REWIND 0xA857
KEY_FASTFORWARD 0x28D7
KEY_PLAY 0x0EF1
KEY_PREVIOUS 0xD827
KEY_NEXT 0x58A7
KEY_STOP 0x9867
end codes
end remote
That’s awesome… Thanks Jace
Works like a charm.!!! Context menu and everything
:o)
Glad I could help!
Forgot to mention the record button on the remote has been mapped to stop. Disp at the bottom does nothing but I think it’s a TV button.
I just got a V4K+
I also have an old X360 remote which is listed as being compatible in the My OSMC >Remotes
I “select” that remote to use but it does not operate my V4K+
Sadly, I can’t access the config file area fom my laptop.
