Hello,
did anyone succeed connecting Xbox one controller over Bluetooth? Device is visible.
I tried both with and without pin without any success.
Thank you!
Jaromir
Hello,
Thank you!
Jaromir
Can’t help you I’m afraid. But I have the same question regarding a wireless PS4 DuelShock controller.
How do you pair it?
Hi, This is how I got my Xbox One controller working on a pi3 with osmc.
if it worked your controller will vibrate. Then just go to your joystick and configure the buttons. Also might need to add the above line to a startup script if it doesnt stay synced after restart.
Hope this helps someone…
