Hello i am new here but i am using osmc since the start of it. Befor i was using raspbmc. Can someone please tell me how to connect XBOX One S controller via bluetooth. Controller is visible but i cannot connect via OSCM with or without pin it is not working. Everytime i get error that pairing failed.
What can i do, i was searching web an this forum and i didnt find anything that worked for me.
Please help
Try using bluetoothctl from command line normally works more reliable
Try putting this in /etc/rc.local
echo 1 > /sys/module/bluetooth/parameters/disable_ertm
reboot and try to pair, first via MyOSMC and if that fails try via bluetoothctl
I have tried everything. I have also found this tutorial which i went and tried and nothing worked. Tutorial is here: xpadneo | Advanced Linux Driver for Xbox One Wireless Controller (shipped with Xbox One S)
I get this:
login as: osmc
osmc@192.168.1.40βs password:
Linux osmc 4.14.78-4-osmc #1 SMP PREEMPT Wed Dec 12 17:58:11 UTC 2018 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri Apr 26 09:15:13 2019 from 192.168.1.6
osmc@osmc:~$ sudo bluetoothctl
[NEW] Controller B8:27:EB:DF:37:5C osmc [default]
[bluetooth]# scan on
Discovery started
[CHG] Controller B8:27:EB:DF:37:5C Discovering: yes
[NEW] Device 1C:5A:3E:70:44:60 TVBluetooth
[NEW] Device 5C:BA:37:28:C5:E4 Xbox Wireless Controller
[CHG] Device 5C:BA:37:28:C5:E4 UUIDs: 00001124-0000-1000-8000-00805f9b34fb
[bluetooth]#
[bluetooth]# pair 5C:BA:37:28:C5:E4
Attempting to pair with 5C:BA:37:28:C5:E4
[CHG] Device 5C:BA:37:28:C5:E4 Connected: yes
[CHG] Device 5C:BA:37:28:C5:E4 ServicesResolved: yes
[CHG] Device 5C:BA:37:28:C5:E4 Paired: yes
Pairing successful
[CHG] Device 5C:BA:37:28:C5:E4 ServicesResolved: no
[CHG] Device 5C:BA:37:28:C5:E4 Connected: no
[bluetooth]# trust 5C:BA:37:28:C5:E4
[CHG] Device 5C:BA:37:28:C5:E4 Trusted: yes
Changing 5C:BA:37:28:C5:E4 trust succeeded
[bluetooth]# connect 5C:BA:37:28:C5:E4
Attempting to connect to 5C:BA:37:28:C5:E4
Failed to connect: org.bluez.Error.Failed
[CHG] Device 5C:BA:37:28:C5:E4 RSSI: -74
[bluetooth]#
I dont know what is wrong. Controller is paired but it wont connect.
I did this in etc/rc.local
I hope i did it ok ?
Well you can verify with cat /sys/module/bluetooth/parameters/disable_ertm
I get this:
I am completly new to the linux and using command
Ok seems not to have worked (I assume you had rebooted already)? For testing letβs do it outside of rc.local
sudo bash
After that try to connect with bluetoothctl without restart.
Sorry it doesent work. I have tried everything you said couple of times but i have no clue what is going on.
Now i have tried again and it works. I dont know what i have done different but it works.
I hope it will be connection from now on ok. Now i am affraid to disconnect
Thank you. Everything works now ok. I hope it will be working when i connect again
