I’m new in the forum and hope to find some help regarding my controller issue.
I’ve just installed RetroPie on my OSMC RaspPi2 following the tutorial on this forum ( [HowTo] Installing RetroPie alongside OSMC RC (the easy way) )
Went quite well and I can now launch emulationstation from kodi and getting warped back when emulationstation quits works like a charm.
I can even use my controllers in emu-station and I can configure them in the “RetroPi” menu where it saves the configuration I enter.
However, once I launch a game in retroarch I am getting no reaction whatsoever to the controller – it is as if it didn’t exist.
I have tried a bunch of things now for two days and none have worked. The route that looked most promising for a while was killing the xboxdrv process that is loading with the xbmc.ini adapted to kodi and starting a clean xboxdrv process as according to retropie’s “how to xboxdrv”… but nothing there either.
Relying on your help - any ideas/input on how to solve this? Much appreciated!
Thanks in advance!
Andreas
