This is almost certainly a Kodi/skin problem and I’ve got the “skin guy” looking at this on the Kodi forums (see link below), but in the off-chance that someone else encounters this or has information to add I’ll describe it here also.
I allowed the August 2024 OSMC update on one of my Vero 4k using the update method (not clean install). It seemed to go smoothly with no errors. On the first load of the Kodi Omega 21.1 there was a pop-up stating that the skin I had been using - Xonfluence - was not compatible with this version of Kodi. No problem, everything seemed to work fine otherwise. I think it may have been the next day or two I noted there was another OSMC update which I also allowed and it also seemed to install without drama.
I noted on Kodi forums there is an updated version of the Xonfluence skin, and has been for some time, which is compatible with Omega. I downloaded it but it will not install. I get the red warning:
Failed to install add-on from zip file
I used to be more “into” the OSMC/Kodi scene but it’s been several years and old age has turned memories into abstract imaginations. Are there current instructions you can link me to on how to export and send a log? If so I can do it this evening.
reproduce the issue
There’s no urgency Sam. I’ve got the skin working, the dependency on that additional addon was removed. It’s mostly functional now, just the image selection part doesn’t work as intended but I can live with that.
Ok, but I would have thought it would have updated two days later but it still failed.
I have several more Vero 4k to update. I’m not optimistic to be honest. I assume I’ll have to kludge them all since that Image Resource dependency doesn’t exist in the Kodi repository, refreshed or not.
