Hi to all ,
I try to generate a Xorg config file running ‘Xorg -configure’ but, I get this error:
http://paste.debian.net/356361/
On OSMC don’t run ‘Xorg -configure’ ?
Thanks, see you.
Hi to all ,
Thanks, see you.
OSMC for Raspberry Pi does not use an X server
Hi Sam ,
I understand that you are referring to an OSMC clean default installation but, for my question, I understood that given the present scenario was after installed X.org via APT-GET(8) utility in system.
Then, after X.org installation, I think we can say that OSMC has X.org because -for example- KDE work fine on OSMC system.
My question is in my present scenario.
Sorry for not explain me better before.
I understand now.
You may want to copy /etc/X11/xorg.conf off a Raspbian installation. I’m not sure how it should look for Raspberry Pi.
