XSqueeze (my title needs 15 characters)
So has anyone successfully gotten XSqueeze to work? Mine keeps saying “cannot connect to player.”
Thanks,
Josh
For anyone that Is interested:
To see if Alsa is running:
lsmod | grep -q snd_bcm2835 && echo “snd_bcm2835 module is loaded.” || echo “snd_bcm2835 module is NOT loaded.”
To start it if it is not (it is not by default):
sudo modprobe snd_bcm2835
Now I just need to figure out how to make it survive a reboot, because rebooting killed it.
And finally, if anyone else searches this and needs this answer, it goes in the /etc/modules file.
sudo nano /etc/modeules
then add "snd_bcm2835 " to it and hit ctrl-x and save the file. Reboot and you should be good.
Hey gijosh28,
I only registered in this forum to say “thank you very much” for your hints. This was exactly the information I was searching for. It worked well. Awesome!
Btw I am sure this is my first but not last post in this forum. I´m new with raspberry at all, and OSMC works fine for me. So thanks to the hardworking developers, too.
urmelostsee
You should add it to /etc/modprobe.d rather than touching /etc/modules directly.
Hi Sam,
thank you for that advice. Could you tell me (as a compete novice to all that linux - RPi - stuff), why? Can only learn…
urmelostsee
