KarVi
#1
Anybody else experiencing this?
My otherwise really stable OSMC, seems to have a tendency to “sad face” when I use Yatse to remote control Kodi.
Cant remember if I have debugging enabled, so maybe these logs arent usefull:
https://paste.osmc.tv/hirutoyeno
Edit:
It has been doing this in the August update also, its not a September update only problem
I’ve been using Yatse for a couple of years now, never experienced anything bad as you say.
From the log I can see something’s not right:
WARNING: Skin Helper Simplecache --> Database ERROR ! -- disk I/O error
WARNING: Skin Helper Simplecache --> Database ERROR ! -- attempt to write a readonly database
WARNING: Skin Helper Simplecache --> Exception while initializing database: disk I/O error
This might be the reason you’re seeing the sad face.
Using yatse on all my machines and never had a sad face caused by it
KarVi
#4
Thanks for the answers.
I really don’t hope its the disk / SD-card, as its an original OSMC card.
I am running a small OC, I’ll try turning that off, to see if that removes the crashes.
I have only seen Kodi crash while I used Yatse, I can still SSH into OSMC, and Kodi allways reloads by itself, so the OS beneath Kodi seems OK.
