Hi, does anyone know the YeeMee add-on and got it working? It seems our Vero 4K+ only works with YeeMee when hardware acceleration is off otherwise YeeMee cannot grab the screen content.
I don’t know anything about this add-on.
It probably doesn’t utilise Vero’s capture interfaces (amlgrabber or ge2d)
Thanks, I asked the developer, he said he is using Kodi’s internal screen grab function. Unfortunately I don’t know what function or command this is.
Is it possible to have Kodi use amlgrabber/ge2d for its internal screen grabber, somehow?
also for me this addon not work cause there isn’t grab function on kodi
https://codedocs.xyz/xbmc/xbmc/group__python__xbmc___render_capture.html?fbclid=IwAR0JKQ54Ccr6LfWlwULWvQjbiA6KgOQd8pKtGnrNhkslaBLw8P5lax02JuQ
