I had issue with the YouTube addon for a few days and I can’t work out why.
I have the addon set up with my own, personal API Keys and everything, that has been working for me for a few months. Until now.
Now the Addon won’t even show the menu at all. It simply gives me an error and a message to look into the logs.
So here they are, can anybody please help me out?
You can either delete access_manager.json by using Settings - Maintenance (will require re-login)
Or you can edit the access_manager.json file in your userdata/addon_data/plugin.video.youtube/ folder to fix the corrupt file. likely a missing or additional }
Thanks you very much, deleting the file and relogging did the trick
+1 Karma for you
