I’ve been using the Vero 4K+ for two months, and it has been working very fine. Since the latest update
(october or november, don’t remember) the color mode is not being set correctly, as did before. I have the Vero4k connected to a Onkyo Receiver, in 1080p mode (not 4K).
I don’t know exactly what mode defaults the Vero4K, but I have my projector configured to YPbPr, and many times when I start up the mode is set to RGB. I have noticed that if I start the Receiver connected to the Blu Ray (instead of the Vero), and then I restart the Vero, sometimes it starts with YPbPr mode.
I know there is a setting to “Force RGB”, but I can’t see the option to force YPbPr.
I have not yet been able to debug the system, but I’m sure that when the Vero starts all the equipment is turned on. I checked it last week because I knew there can be problems when the devices do not respond to the EDID messages.
Anyway, I usually do not power off, I only suspend. Is it normal that if I suspend in YUV mode, the mode changes when I take it out from suspension? This happened to me last week, which I thought it was strange.
How does the hotplugging work exactly? I have the Vero connected to the receiver, and the receiver outputs to the tv and the projector, so depending which of them is powered on, the vero will detect differents EDIDs. Maybe this is the problem. But both of them are YUV capable, so the default should be YUV.
When I restarted the system, the screen was ON, and also the receiver. It seems that the screen settings are getting the fallback configuration, but I don’t know why exactly.
The point is that I want it to be configured as YUV, because the Blu Ray and projector are this way, but when I connect the Vero, sometimes it changes to RGB, and I have to change my projector configuration, and then again when I connect to the Blu Ray.
I don’t know why the Vero is changing the color mode. Someone can see something from the logs
(Maybe in options there could be an option to force YUV also…)
Sorry, that setting should not have to be on. I tried many things and at the end I let the RGB mode on and projector to RGB to be able to use it without changing the settings every time it boots up.
THIS is the log without the RGB mode on, the projector set in YUV mode, and after reboot, the Vero does not output YUV, but RGB.
Dec 02 23:26:25 osmc kernel: hdmitx: video: VIC: 16 (16) 1920x1080p60hz
Dec 02 23:26:25 osmc kernel: hdmitx: video: Bit depth: 10-bit, Colour range RGB: limited, YCC: limited, Colourspace: YUV444
Dec 02 23:26:25 osmc kernel: hdmitx: video: Colorimetry: bt709
Dec 02 23:26:25 osmc kernel: fb: osd current vmode=1080p60hz, cmd: 0x10000
Dec 02 23:26:25 osmc kernel: fb: osd[0] enable: 1 (kodi.bin)
This is telling me we are sending YUV. You can double-check by typing at the commandline cat /sys/class/amhdmitx/amhdmitx0/config
I don’t know what to suggest, really. Can it be an issue with your AVR?
