Since a few days my Zattoo PVR Client doesn’t show any channels anymore, time schedule keeps staying empty. After system startup, a blue banner with the title “Zattoo PVR client” and no text pops up.
Same applies to a fresh installed system. What to do?
You are not using the latest available version which is 18.1.15. While that one also is quite old I at least would suggest to update to that.
But anyhow locking at the Github where the latest version 19.2.16 it might need that you manually install that version if 18.1.15 also is not working.
I’m not bothering building my own stuff or install something manually (How-to available somewhere?) - I tend to use ‘Update’ in the UI, and this says, there’s no new version. Why?
Remember, my OSMC distro is from this afternoon, freshly installed, so no side effects from anything.
Add the following line: deb http://apt.osmc.tv stretch-devel main
If the instructions aren’t clear, I’d advise waiting for the next stable release.
But there is no guarantee at all that this will solve the problem. We don’t have any logs from you about the issue.
Matrix is the next version of Kodi. It will be Kodi v19.
The reason why the add-on in the Matrix branch seems so far ahead (v19 vs v18) is that it’s targetting Kodi v19 which is yet to be released.
Same problem again: Zattoo PVR Client doesn’t show any channels anymore, time schedule keeps staying empty. After disabling/enabling the PVR addon, a blue banner with the title “Zattoo PVR client” and no text pops up. Backup waipu.tv addon shows channels, but streams don’t start. What to do?
