I thought I should start by asking this question before I reinstall OSMC on my VERO 4k
I been away from home the last 12 weeks and when I got back I did an system update.
After the upgrade, there is a noticeable delay before the music begins after selecting a song - around 20-25 seconds. During this time the system is locked. It’s the same result if I use Veros own remote or the iPhone remote app.
The delay doesn’t happen between songs if I play an album, but if I switch from one album to the other there is a new delay.
I am reluctant to assume this is a problem with my NAS, I do not get any indication there is buffering going on, and if I start any videos they begin playing more or less immediately. Videos are stored on the same disk/different partition on my NAS as the music files.
I would assume it’s just you as otherwise the forum would be full of complains.
So if you want to do some analytics before reinstalling suggest to provide debug logs for us to help.
Also check which Audio Output you have configured.
navigate to and start playing one song (waiting time ca 25 sec)
start the next song on the same album (no waiting time)
navigate to and start playing a song on another album (about 25 sec waiting time)
I then went to Settings/System/audio to check the output, but it was the standard one for my TV. I have been using two different USB DAC previously, but with no different results.
The 30 seconds seems to be picked up somewhere in the caching time. Could you try to play the file from the internal drive to test if it might be related to network?
put a few songs in the home/music directory and played.
they played fine, and when i went back to play from the library (networked) it was till the same. I did however notice that sometimes a song would play right away even from the networked volume.
I also never experienced a lag when playing videos.
Any indexing service activated on the NAS which analyses the data, first?
Can’t even say for sure that it is a problem with the NAS, I have run the same setup for at least 6 months with VERO 4k up until the end of September when I had to go away for work, and never had any issues.
Hibernation is hardly an issue neither at the NAS or the VERO, and while the NAS do have indexing services they run at need and have also never affected the playback before.
Also, wouldn’t those issues affect ALL files that I try to play from the NAS? Video files do so far seem to be unaffected.
Been spending the last hour trying to install iperf3 on my Synology DS414j NAS, but get error messages no matter what I do. Install on my VERO went fine though.
If it is easier to install iperf (instead of iperf3) on the NAS than can also use that.
Anyhow as you mentioned maybe it is not a NAS/Network issue. Then a reinstall might be the fastest way to clarify. Or you first try a clean Kodi install.
Let’s test with Kodi default settings. Enter the following commands with an SSH connection.
I tried to get back to default settings, but realised i cannot reach the network by browsing so i cant test the music files without editing forgot-the-name-of- the-file-to mount-NAS-drives again, and that will take a while.
