I had a stable setup, have not changed anything only applied the latest update: 2017.12-1. I have an NFS server on RPI3. It was working fine until now with the following /etc/exportfs
But today I realized that is has huge delays when I try to play something on my laptop from this nfs share.
I know it was a huge update and the rest is working well for me, but what could be the problem? What kind of setting is missing for me to have a performant enough nfs share?
Are you mounting via fstab, or kodi nfs:// mounts?
thanks for the answer. Evening I try to collect the necessary logs. To describe the problem maybe more precisly the RPI is acting as a NFS server. On my laptop I mounting it with fstab (so the laptop is the client and osmc is the nfs server). The above /etc/exportfs is on the rpi(osmc) side. There was no change on my rooter side, neighter on the laptop side. And now the problem when I try to reach any file from osmc on the laptop and for example I try to play on the client any kind of video file, which is fine on the server (osmc kodi) is tearing on the client side. Independently which video player I’m using. It was not the case before the update. So some kind of performance of the NFS server is not as good as before. Do you have any special log what I should share with you?
