some advice needed. my vero 4k is connected to my home network. I stream everything from my local win7 pc through samba / smb
everything 1080p related is never a problem, but I of course bought the vero 4k to watch 4k.
first movie I tried, I think I ran against big buffering issues. Audio would suddenly drop out while video continued for a minute or so. Pausing the movie for a few secs fixed it … until a few min later happened again. Audio goes through my receiver. And it’s both with atmos or dts-hd.
Found out here I needed to update my cache settings in advancedsettings.
is what I have now. It’s better, but still get some stutter/ audio drops from time to time (once or twice as opposed to 20 times).
So I presume I need to up my memorysize a bit.
What would be a good size to try to get clean throughput ? I don’t want to just double it … since of course starting a movie will just take longer, and so far 90% of what I watch it still 1080p
I’m quite sure my network is fast enough (I download at 200 Mbps).
Movies I played / tested with so far were all uncompressed.
MI6 ; Ralph 2; Venom; Suicide Squad Hell To Pay.
I’m going to test Aquaman from a HDD connected to the vero to rule out other problems.
Tnx for some suggestions on the cachesize
OkI’ll give that a go. 2 quick questions before I try that… 1. It has to be IP? It can’t be the server name… Since it’s not a fixed ip. And 2…will the library need to Be reloaded? Causeit’s a big one… And not looking forward to resetting the watched status
I think hostname should work instead of ip. As for library, I think it needs reloading but you might be able to trick it providing you mount the new library with the same name as the current library, i’m Not 100% sure on this though.
If you bought it on Black Friday 2018, it’ll be a 4K +
OP shouldn’t need to do an fstab mount if he has a 4K + and has Gigabit Ethernet.
Can you go to My OSMC -> Logs and upload a set of all logs and send us the URL so we can check a couple of things?
yes it’s a 4k+ …says so in system.
ok … n00b question … is the logging automatically on ? Meaning I can just do the upload of it ? And it’ll have the info needed (from previous files watched )… or do I first need to turn it on ? And then play a troublesome file until I get the problem … and then upload ?
Nope, we need debug logs. Follow the instructions in the link @Tom_Doyle kindly provided to enable debug mode, play a movie till it stutters, upload the logs and paste the shown url here.
not sure if I did it right … cause the logfiles were 11Mb again (even after rebooting twice … I can upload it elsewhere if needed). I just used the kodi.log file from the debugging
So I rebooted and played the 4k file which has given me the most trouble so far (MI6).
After about 15 secs, it froze … with message on screen “Source Too Slow For Continuous Playback”.
After a few secs, it continued. The problem then started around the 9min mark. Video would continue to play … audio gets out of sync and then disappears completely. If I pause the movie … wait around 10secs or so and continue … it’s fine again. Depending on the movie … I have to repeat this several times during.
Can it be the HDD on which the files are placed ? I have 1 WD Red in my machine, and 2 WD Blue’s. It just occured to me that all 4k files are on the WD Blue.
EDIT : not the HDD’s … copied the file to the WD Red, same problem
EDIT2 : deleted old dates from the uploadlog … and posted the rest http://paste.osmc.tv/onikuzazit.md
