To get a further understanding of the problem you are experiencing we need more information from you. The best way to get this information is for you to upload logs that demonstrate your problem. You can learn more about how to submit a useful support request here.
I think it would be good to see a debug log and MediaInfo first.
I’d connect an Ethernet cable temporarily (and reboot) to see if this improves things.
For the music playback on my PI’s, without the cache settings, I always have audio-dropouts.
Reason I thought about that.
On the Vero 1, I also had to do that and add a Wireless router to it, as it had better Antennas and better throughput.
I tried the video cache suggestion and it also did not work, there was still lots of buffering/stuttering.
Tonight I will copy the file to usb and try playing it directly in the vero. I was really hoping the wifi ac transfer rate would be able to handle the movie, I guess not.
