I have a Raspberry Pi 2 with a D-Link DWA-171 wireless adapter that’s been working fine for the last year or so, but right after applying the February update and rebooting, the WiFi didn’t come back up. I found that it’s only the 5 GHz connection that doesn’t work. I’m able to connect via 2.4 GHz to the same AP, though 2.4 GHz in my area is so congested that it’s not usable for streaming anything.
I included the dmesg output below, with my SSID and BSSID masked. Has anything changed in the rtl8812au driver in this release? mySSID-5G is the 5 GHz SSID, and mySSID is the 2.4 GHz one. Thanks.
[ 4.858753] usbcore: registered new interface driver rtl8812au
[...snip...]
[ 171.767676] RTL8812: set ssid [mySSID-5G] fw_state=0x00000008
[ 171.767918] RTL8812: set bssid:xx:xx:xx:xx:xx:xx
[ 171.796713] RTL8812: start auth
[ 173.349362] RTL8812: indicate disassoc
[ 182.359553] RTL8812: set ssid [mySSID-5G] fw_state=0x00000008
[ 182.359895] RTL8812: set bssid:xx:xx:xx:xx:xx:xx
[ 182.446522] RTL8812: start auth
[ 182.448619] RTL8812: auth success, start assoc
[ 182.459342] RTL8812: indicate disassoc
[ 185.979403] RTL8812: nolinked power save enter
[ 186.623041] RTL8812: nolinked power save leave
[ 192.498298] RTL8812: set ssid [mySSID-5G] fw_state=0x00000008
[ 192.498379] RTL8812: set bssid:xx:xx:xx:xx:xx:xx
[ 193.301227] RTL8812: start auth
[ 193.314993] RTL8812: auth success, start assoc
[ 193.319346] RTL8812: indicate disassoc
[ 203.259441] RTL8812: nolinked power save enter
[ 206.428350] RTL8812: nolinked power save leave
[ 212.319818] RTL8812: set ssid [mySSID] fw_state=0x00000008
[ 212.320068] RTL8812: set bssid:xx:xx:xx:xx:xx:xx
[ 212.581491] RTL8812: start auth
[ 212.662152] RTL8812: auth success, start assoc
[ 212.691046] RTL8812: assoc success
[ 212.693936] UpdateHalRAMask8812A => mac_id:0, networkType:0x0b, mask:0x000fffff
==> rssi_level:0, rate_bitmap:0x000ff005
[ 212.707731] RTL8812: send eapol packet
[ 212.721347] RTL8812: send eapol packet
[ 212.722818] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 212.724207] RTL8812: set pairwise key to hw: alg:4(WEP40-1 WEP104-5 TKIP-2 AES-4) camid:4
[ 212.724230] RTL8812: set group key to hw: alg:4(WEP40-1 WEP104-5 TKIP-2 AES-4) keyid:1
[ 213.581668] UpdateHalRAMask8812A => mac_id:0, networkType:0x0b, mask:0x000fffff
==> rssi_level:2, rate_bitmap:0x000ff000
[ 286.381845] UpdateHalRAMask8812A => mac_id:0, networkType:0x0b, mask:0x000fffff
==> rssi_level:1, rate_bitmap:0x000f0000
