I installed 4.9 kernel . Whitelisting is enabled.
And there is the same issue regarding a blue ray start (BDMV container) with 25FPS and 29.970FPS as in latest stable June release.
Like example push play on remote:
comes sound and video almost on the same time, but after about second sound and video disappear (black screen) and after about one second or two movie starts play normally with sound and video. (There is no this black screen for second or two with 23,973FPS blue ray video )
First:
I tried to connect Vero 4K directly to Panasonic TV (Plasma). Without AVR
And play first a blue ray movie with 23,973 FPS.
Media info of the file https://paste.osmc.tv/exomayonus.coffee
Starts very smoothly. If I enable debug information on the screen it confirms that fr: 29.976 drop: 0 skip:0
After that I play a blue ray with 25FPS
Here is media info file https://paste.osmc.tv/wetigopeme.vhdl
Now video starts TV is confirming 25hz 1080p, but then black screen for second or two without audio. And then everything plays fine, except TV confirms that it is 50hz instead of 25hz and then I enable debug information on screen, it shows:
fr: 50.000 drop: 0 skip:104
Now I start Blue ray video with 29.970FPS
Media info file https://paste.osmc.tv/oyiwiverah.rib
The same issue: Audio and video starts TV is reporting 30hz 1080p,but then black screen for second or two without audio. Then everything plays fine, but TV reports 60hz 1080p and if I enable debug information on screen it shows:
fr:59.940 drop:0 skip:115
So here is my log with vero 4K connected just to TV and above described scenario
https://paste.osmc.tv/acewujotol
Second:
I connected Vero 4K to AVR Denon and then to TV
Played exactly the same files as described above :
Start movie with 23,973 FPS ,starts very smooth without black screen with 23,973 FPS.
Start movie with 25FPS: starts with 25FPS, then black screen for second or two and then plays fine, but with 50FPS.
Start movie with 29.970FPS: starts with 29.970FPS, then black screen for second or two and then plays fine but with 59.940FPS.
So here is log Vero 4K connected to AVR and when to TV (files used is exactly the same as media info indicted above)
https://paste.osmc.tv/horubaxahu
When I just disable whitelisting (Kernel 4.9) or as it was tested on latest stable June realese:
Everything starts very smooth without black screen, but frames per second any way is changed for 25FPS video to 50FPS
and 29.970 FPS video to 59.940FPS
PS: I like Vero 4K and OSMC very much and want to thank you for the great job
