Adding nordvpn
Hi, new user and not very technical but want to add a VPN to my Vero v box.
What is the quickest and easiest way to do this, have an account with nordvpn?
This thread may help: https://discourse.osmc.tv/t/vero-v-what-vpns-currently-work-with/108064
Thanks but seems complicated, and the computer coding is likely beyond me.
Is there an add on I can use to bypass all that, as more familiar with those?
I’m coming from an android box and only ever used a simple set up in Kodi with the Nordvpn app switching itself on when the box comes on.
This page explains step by step how to install and setup the Zomboided VPN Manager for OpenVPN (for OSMC). I didn’t try that myself but since it’s a recent blog (Nov 2025), and referred to from LinkedIn, it may work: https://www.geekersdigest.com/how-to-use-nordvpn-in-kodi-on-osmc-or-libreelec-devices/
Will have a read through that tomorrow.
Appreciate the help, thanks.
All up and running now, that guide was a great help… only had to load two files to a usb
Found this thread also very helpful for the fix
