Having to add a repo from the kodi systems settings / File Manager
The wanted repo is in the list now, but when I return back to the Kodi Home page Add-Ons page, the repo doesn’t show when installing from repository is selected…
I’m getting buffering issues and trying to use a fix from top tutorials…
Any words of advice how I can add a repo the old Kodi way or get this working?
Buffering only can help with a fluctuation in bandwidth not with constant under performance.
As I wrote Buffer settings on Vero4k are optimized already for the memory that the 4k has.
Suggest to check your network performance with iperf3 and compare that with the required bandwidth of the file you want to play.
Depending on the file sharing protocol you use you might also be able to improve on that.
But all my files are standard non 4K files. Approx size around 700 mb - 1.5 Gb mkv files…
I am not a tech guy to say so I’m not sure about much. But it seems it should work a little better. I bought 4 boxes and am generally been happy with a hard drive connected to the 4K, but am increasingly getting frustrated after trying to place my media on a NAS or the like.
I have no idea what iperf3 is or what that means…
Sorry…
I bought these units because of simplicity. Had Kodi Raspberries since #1 and thought this was going to be a foolproof out of the box solution…
The Vero might not have picked up the right CRDA and therefore block Channel 12.
Suggest you use 1, 6 or 11 and maybe also first check with an APP on your phone (network scanner) which one is the most occupied one.
