I just upgraded the vero4k via dist-upgrade (April update).
Now Kodi (mediacenter) crashes all time and restarts again.
It’s just a few seconds up and then restarts. But It’s only kodi not the entire system.
Here are my logs: https://paste.osmc.tv/jecitihoho
Debug logging can be enabled under Kodi settings.
All versions of OSMC are available at osmc.tv/download.
I’m sorry to hear things aren’t working as expected for you but the first step is to see if it’s related to a specific version of OSMC and then to take things from there.
I fixed this problem by starting from scratch and installed the march version of osmc.
But now I have a problem with the HW acceleration.
After installing the march version of osmc, I tried to play a mkv-file. This works great.
Then I updated to the april version via myosmc/update. The update runs without any issues and kodi started again.
Then I played the same mkv-file again, but now it only played several seconds of the audio stream and no video is shown. Then the “buffering…” popup showed up but nothing happened.
I found out, that if I set HW Acceleration in h264 from “hd and up” to “never” the mkv-file is played.
It’s a little bit stuttering, but it plays.
If I change back to HW Acceleration, the problem occurs again.
I installed osmc several times, but always after updating to the april version of osmc the HW acceleration breaks.
I’ve got exactly the same problem after I updated to april update.
Everything worked great with the March update.
I am using HDMI through a receiver.
As soon as I disable hw acceleration it works.
ok, I tried a lot, but I can’t get it working.
It’s always the same: The march version is working and with the april version I get this issue.
And I don’t have time to search much longer for the reasons.
The only option I see, is to stay on the march version. Perhaps I can block this update, so I can at least update the rest.
But as I just bought the vero4k it’s a little bit frustrating. The years before I had the raspberry pi 1 and I never had any issues with osmc.
These settings are the result of reinstalling osmc perhaps 10 times. I definitely use other audio settings on my “productive” system. But if you install osmc that often, you just look if the video is playing and not if all settings are correctly set.
I really hope if there are other users with this issue. Especially as the problem affects even the Big Buck Bunny clip.
I also encounter this problem but then with blu-ray files with the April update.
The movie starts but after 30 seconds or so the movie will slow down, starts buffering and the screen goes black with, also sound is gone.
When I try to play the same file with my Shield running Kodi 17.1 it plays fine. Didn’t encounter the problem before the April update.
Will try to upload the logs ASAP but the wife has taken over the remote.
I want to go back to March version but don’t have a micro-sd:disappointed_relieved:
Is there any way to go back to the March version without SD???
