After August update massive stuttering on 25 FPS videos
No i’m afraid it’s not fixed. Tried everything. I’m back at the march update now which has no problems with 25 FPS videos
Forgot to put logs
HTTPS://paste.osmc.tv/vomavuhisa
@GuraxDax … not glad to hear, but then I presume it’s a bigger issue.
@sam_nazarko could you remove the notion from the thread that it’s solved please as well? Since it’s not so far
I’ve removed solved mark as requested.
Your logs would be more useful if you enable debug logs please?
Regards Tom.
Sorry yes
HTTPS://paste.osmc.tv/naqofiquyo
Or https://paste.osmc.tv/naqoflquyo
Not sure if it’s an I or l
Its the first one.
I also experienced this stuttering today, Vero V, August update.
This was not a problem before with the previous version.
Strange thing is, when playing 2 different 25 fps tv shows, one shows 25 fps in the technical details and stutters a lot and the other one shows 50 fps in the technical details and is very smooth. I did not create any logs yet, as there are other logs in this thread. But if needed, I can generate them.
Mediainfo of the stuttering show (Strike Season 6):
Format : Matroska
Format version : Version 4
File size : 3.18 GiB
Duration : 55 min 56 s
Overall bit rate : 8 134 kb/s
Frame rate : 25.000 FPS
Writing application : mkvmerge v77.0 (‘Elemental’) 64-bit
Writing library : libebml v1.4.4 + libmatroska v1.7.1
Video
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 2 frames
Format settings, GOP : M=3, N=50
Format settings, Slice count : 2 slices per frame
Codec ID : V_MPEG4/ISO/AVC
Bit rate mode : Constant
Bit rate : 7 830 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.151
Stream size : 3.05 GiB (96%)
Default : Yes
Forced : No
Audio #1
Format : E-AC-3
Format/Info : Enhanced AC-3
Commercial name : Dolby Digital Plus
Codec ID : A_EAC3
Bit rate : 192 kb/s
Channel(s) : 6 channels
Sampling rate : 48.0 kHz
Compression mode : Lossy
Stream size : 76.8 MiB (2%)
Language : German
Service kind : Complete Main
Default : Yes
Forced : No
Dialog Normalization : -23 dB
compr : -0.28 dB
dmixmod : Lt/Rt
ltrtcmixlev : -3.0 dB
ltrtsurmixlev : -3.0 dB
lorocmixlev : -3.0 dB
lorosurmixlev : -3.0 dB
dialnorm_Average : -23 dB
dialnorm_Minimum : -23 dB
dialnorm_Maximum : -23 dB
Audio #2
Format : E-AC-3
Codec ID : A_EAC3
Bit rate : 128 kb/s
Channel(s) : 2 channels
Stream size : 51.2 MiB (2%)
Language : English
Default : No
Forced : No
compr : -0.28 dB
dsurmod : Not Dolby Surround encoded
and for comparision, the video part of a non stuttering file:
Video
Format : AVC
Format settings : CABAC / 4 Ref Frames
Format settings, Reference frames : 4 frames
Duration : 40 min 23 s
Bit rate : 4 062 kb/s
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.078
Stream size : 1.15 GiB (89%)
Default : Yes
Forced : No
I can reproduce that issue and will have a look.
hi, any update here on what the cause is … and eta for a fix ?
Yes, I have an update for you :slight_smile: . Since yesterday, that issue is fixed. If you want, you can check it out on staging:
  1. Login via the command line
  2. Run the following command to add the staging repository:
  3. Go to My OSMC → Updater → Manual Controls → and select Check for Updates now. When prompted to do so on screen, please choose to install the update.
  4. Your system should have have received the update.
I also recommend you remove /etc/apt/sources.list.d/osmc-devel.list after updating.
This will deactivate the staging repository. You can do so with the following command:
sudo rm /etc/apt/sources.list.d/osmc-devel.list.
I checked this Vero-V staging software update, with the file in post -
(After August update massive stuttering on 25 FPS videos - #6 by GuraxDax)
And I can confirm the stuttering has gone.
Awesome. I can also confirm the stuttering is gone. Tnx for the fix guys !
To be curious, what went wrong in the first place ?
We made some changes but there was a regression
This is now solved
Hi… Unfortunately I have to get back on earlier success ’
I tried with 1080p which was fine.
Now trying with 2160p with hdr… And it’s even worse than before. Audio skipping… Stuttering…
I’ll upload some new logs in a second.
Here the new logs
Https://paste.osmc.tv/denudepoxe
I need more info, a debug log is not enough. So please additionally to the debug logging, turn on component logging and activate the a/v sync and video component logs. Then reproduce the issue and post the logs.
I could also see
2025-09-09 22:55:52.554 T:3306    debug <general>: CFileCache::IoControl - setting maxRate to 14.06 Mbit/s with processWait of 95 ms
2025-09-09 22:55:52.554 T:3306    debug <general>: CDVDInputStreamFile::SetReadRate - set cache throttle rate to 1843013 bytes per second
which suggests that such a limited read rate will cause issues with 4k playback.
Will do so.
I have no 4k issues with non 25fps files btw. Doing 70 GB UHD remuxes go perfect.
And here the logs with the additional info turned on
Https://paste.osmc.tv/uhaxagexos
I want to stress again that its only on 25fps that 4k (hdr / dv) is giving issues. 94% of what I watch is 4k. If needed or wanted, I can cut a piece of video and upload it somewhere for you to test.
I have no issues with 2160p 25Hz or 50Hz here, playing from a USB disk. A clip might help.
No problem …I made a 5min clip
used wetransfer, so only 3 days valid … if you want me to upload elsewhere, let me know please.
@grahamh
You didn’t have any issues with stuttering videos from the start, so why should you have a problem right now? :wink:
