hbbs
31 January 2016 23:07
#1
Hi there,
After the latest updates my HifiBerry Digi+ stop working.
My default card is now bcm2835.
osmc@osmc:~$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
Subdevices: 8/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
Subdevices: 1/1
card 1: sndrpihifiberry [snd_rpi_hifiberry_digi], device 0: HifiBerry Digi HiFi wm8804-spdif-0
Subdevices: 1/1
Is there a way to undo this?
Please, let me know
hbbs
31 January 2016 23:11
#2
I’ve just found that there is a topic open about this issue on the HifiBerry forums.
Hello,
My DAC+ was working well until an osmc update today.
Now, Hifiberry is not available in sound config anymore, and I have another soundcard in aplay -l output :
$ aplay -l**** Liste des Pér...
Same problem with hifiberry dac+ i have the same output of hbbs but my card1 is hifiberry dac + try to reconfigure but nothing work.Yesterday all working fine… (i found also my video settings on Desktop instead of 1280x1024).The solution is written in other forums…Add dtparam=audio=off to your config.txt file. Reboot and all work!! Maybe you need to re-set audio output in settings system audio output.
hbbs
1 February 2016 00:48
#5
Indeed, I should have searched more. To my defense, I was doing it on my Android.
Thanks, it is working.
