After october update HIFIberry Digi doesn't function
Hi.
After October 2019 10-1 Update (before I had July Update) the HIFIberry Digi doesn’t function. All the videos in Dolby Digital are without sound. Only if i Turn off the passthrough the viedeos are with sound but without Dolby Digital.
In Setup/ System/ Audio i’ve selected ALSA Defaul (snd_rpi_hifiberry_digi, analog)
in MY OSMC / PI Config / Hardware Support / Soundcard Overlay i’ve selected hifiberry-digi-overlay
but under there is this sentence: Warning: GPIO remote support with default pins icompatible with HIFIBerry and i…
in OSMC Pi Config Editor i’ve selected
dtoverlay=hifiberry-digi-overlay
thanks.
Could you please try change config.txt to:
and reboot.
According to this page:
https://www.hifiberry.com/docs/software/configuring-linux-3-18-x/
looks like the settings using by My OSMC addon (dtoverlay=hifiberry-digi-overlay) is no longer used.
I think normally if you have installed only one HAT the correct overlay is set by HAT no matter what is in config.txt, but when you using more HATs (i.e. TV hat and Hifiberry digi) it is necessary correct setting for both HATs in config.txt.
Maybe in last update is something what broken automatic download of overlay from HAT.
Jan
Hi @JanS i’ve tried to change config.txt to
and reboot
but all the video in dolby digital have been without sound yet (with passthrough turn on)
Bengio
could you send some logs please?
or maybe downgrading of kernel will show if this problem is new kernel related.
sudo apt-get install --reinstall rbp2-image-4.14.78-4-osmc
sudo dpkg-reconfigure rbp2-image-4.14.78-4-osmc
Hi @JanS
i’ve tried to downgranding of kernel like you’ve suggested
here is the log https://paste.osmc.tv/uhuyomeyih
thanks.
Bengio
*new version of 11PM
with downgrading of kernel i’ve seen only now that in system / Audio/ audio device there is also “ALSA: snd_rpi_hifiberry_digi, S/PDIF” that before there wasn’t.
i’ve selected this device and now the video in dolby digital has sound with passthrough turn on.
what does it mean?
thanks
Bengio
Hi @bengio
I´m not sure , but if now after downgrading it is working, I think the problem is in the new Kernel which adjusted wrong output for the sound.
[ 4.686495] snd-hifiberry-digi soc:sound: ASoC: CODEC DAI wm8804-spdif not registered - will retry
[ 5.071234] wm8804 1-003b: revision E
[ 5.076901] snd-hifiberry-digi soc:sound: wm8804-spdif ↔ 3f203000.i2s mapping ok
Do you have some logs from new kernel 4.19?
I think that “ALSA: snd_rpi_hifiberry_digi, S/PDIF” was also before updating correct. Can you confirm what you have set before update?
Jan
Edit: What you mean *new version of 11 PM? The Kernel 4.14 is older.
Hi @jans
I haven’t log with the new kernel 4.19…
Yes, before upload i’ve setted Alsa…s/pidf
and after upload there wasn’t Alsa…s/pidf but also alsa…analog
Bengio
Hi @bengio
Can you make some test with another sd card with libreelec which use also kernel 4.19?
If Hifiberry card working and what is necessary set in kodi?
If it will be working, I hope will be possible to find some solution also for OSMC kernel - but definitely will be necessary some logs from new OSMC kernel 4.19.
Unfotunatelly I have not actually access to Hifiberry card for my test.
Jan
Hi @JanS
I am experiencing exactly the same problem with the latest update :frowning:
My logs are here https://paste.osmc.tv/ozukiwowap
Let me know if it’s still necessary to install librelec (I hope it’s not :wink: )
Fallling back to previous kernel version now…
osmc@osmc:~$ sudo apt-get install --reinstall rbp2-image-4.14.78-4-osmc
Reading package lists... Done
Building dependency tree
Reinstallation of rbp2-image-4.14.78-4-osmc is not possible, it cannot be downloaded.
The following package was automatically installed and is no longer required:
  rbp2-image-4.14.78-2-osmc
Use 'sudo apt autoremove' to remove it.
osmc@osmc:~$ sudo dpkg-reconfigure rbp2-image-4.14.78-2-osmc
Running depmod.
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.14.78-2-osmc /boot/vmlinuz-4.14.78-2-osmc
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal-osmc 4.14.78-2-osmc /boot/vmlinuz-4.14.78-2-osmc
run-parts: executing /etc/kernel/postinst.d/inform-updater 4.14.78-2-osmc /boot/vmlinuz-4.14.78-2-osmc
run-parts: executing /etc/kernel/postinst.d/process-vmlinuz-rbp 4.14.78-2-osmc /boot/vmlinuz-4.14.78-2-osmc
osmc@osmc:~$ systemctl reboot -i
Digital output is back again together with mutichannel audio :slight_smile:
Thx for help!
tiroy
I also have the same issue, the 2019.07-1 version allows me to select ‘ALSA: snd_rpi_hifiberry_digi, S/PDIF’ and then output DTS audio to a receiver via passthrough, if I run a manual update to 2019.10-1 (or do a clean install to 2019.10-1), that option disappears and only ‘ALSA: …analogue’ is available, so no audio over passthrough…
Hi @tiroy
I think you have not switched on debug mode when you sending the logs:
2019-11-10 11:27:06.122 T:1916077616  NOTICE: Disabled debug logging due to GUI setting. Level 0.
2019-11-10 11:27:06.122 T:1916077616  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
Second: In the config.txt you have not setup correct overlay (don´t use for setup selection of sound card in MyOSMC addon). Correct is:
Please check this documentation:
which I posted in this thread before few days ago
Please try in kernel 4.19 add to config.txt
dtdebug=1
then reboot and after reboot please show us output of:
aplay -l
dmesg
and
sudo vcdbg log msg
Downgrading to previous kernel it is not final solution, because you can not upgrade in the future. (after upgrade you will recieve new kernel again)
Unfortunately I have not actually any hifiberry card to test in libreelec, but I hope, that if somebody with hifiberry install libreelec, we can check if there is working and which packages is installed there.
In Libreelec forum I can´t find any logs about hifiberry and latest version 9.2 Beta 2
Jan
Hi @JanS
Here’s the requested data, I have executed your setup instructions.
http://paste.osmc.tv/xusicowabi
I´m not sure about these logs. For me looks like new kernel has problem with reading of firmware from HAT EEPROM:
[ 4.541850] snd-rpi-wm8804 soc:sound: ASoC: CODEC DAI wm8804-spdif not registered - will retry
[ 4.551448] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.567398] wm8804 1-003b: Linked as a consumer to regulator.1
[ 4.568716] wm8804 1-003b: revision E
[ 4.570005] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.572575] snd-rpi-wm8804 soc:sound: wm8804-spdif ↔ 3f203000.i2s mapping ok
[ 4.739733] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.747256] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 4.754449] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 4.754461] cfg80211: failed to load regulatory.db
and also change using of overlays between version 4.14 and 4.19
002750.633: Failed to load HAT overlay
002750.700: brfs: File read: 280 bytes
002772.057: dtdebug: Failed to open overlay file ‘overlays/hifiberry-digi.dtbo’
002780.141: dtdebug: Opened overlay file ‘overlays/hifiberry-digi-overlay.dtb’
002780.951: brfs: File read: /mfs/sd/overlays/hifiberry-digi-overlay.dtb
002809.653: Loaded overlay ‘hifiberry-digi’
002809.781: dtparam: audio=off
In system journal log from kernel 4.14 where is working it is writen:
osmc kernel: snd-hifiberry-digi soc:sound: wm8804-spdif ↔ 3f203000.i2s mapping ok
in system journal log from kernel 4.19 is written:
osmc kernel: snd-rpi-wm8804 soc:sound: wm8804-spdif ↔ 3f203000.i2s mapping ok
Maybe @sam_nazarko can explain it better - some different libraries?
@tiroy could you please post complete debug logs from kernel version 4.19? (System>System>Logging>Enable debug logging), reboot, and send full logs
Jan
Unfortunately I don’t have any modern HifiBerry hardware to run on a Pi anymore, so can’t suggest much.
Here they are
https://paste.osmc.tv/ewohilabeh
It can be something similar?
Jan
@tiroy Could you add please for some test to config.txt
dtoverlay=i2c-bcm2708
and reboot and full logs?
Jan
Unfortunately not.
Uploaded https://paste.osmc.tv/ukeyovimar
Same problem here. Reverting to the 2019.07-1 image fixes the problem. With the latest kernel the S/PDIF-output is no longer recognized.
