Hello again,
I posted almost the same question 2019
I still use the same hardware, RPI 3B+
Yesterday I reinstalled my OSMC with version 2021.12-1
I managed to get Netflix installed (and HBO Max and Disney+).
But again I experience that the sound is out of sync and the video is buffering a little and the frame rate is a bit flickering with Netflix. With the HBO and Disney it works fine.
I tried to lower the resolution to 740*480, but the problem remains,
It seems that I manage to fix this back in 2019, but now I do not. Do you guys got any advice for me?
Best regards
Fredrik
reproduce the issue
If it’s the latest (released this January) downloaded by Inputstream Helper then that caused the same problem with me.
You can roll back to the previous one. You can either do this by restoring from backup in Inputstream Helper settings or if the backup doesn’t exist then you could use the option in HBO Max settings or Slyguy Common settings to re-download it.
I activated debug-logging.
I rebooted the system, twice.
I started Netflix, really bad image quality, but the sound seems to sync.
I started HBO, the image quality ia better but buffering a lot, sound seems to be out of sync.
Same with Disney+.
I will try to see if I can figure out what version of Widevine I use I am not sure how to use an other version though.
Best regards
Fredrik
Hi again,
I have to admit that I found it a bit hard to find out the version of Widevine.
I tried:
osmc@osmc:~$ apt-show-versions Widevine
Widevine not installed (not available)
What do you think is the correct way to print out the version of Widevine?
Best regards
Fredrik
Hello,
My version of Widevine was 4.10.2391.0, so I downgraded it to 4.10.2252.5 with Services > SlyGuy Common > Configure > Advanced, Then (Re)install Widevine CDM
Now:
Disney+ works excellent
HBO Max works ok
Netflix works pretty decent a bit “grainy”
So far I think I have to be satisfied, but if you guys know any tricks to fine tune Netflix I am all ear.
How ever thanks a lot for your excellent help guys!!!
Thanks for this, i was going mad because all streams from the two streaming providers i’m paying for suddenly started to buffer after 2 seconds, play for 1 seconds, buffer for 5 seconds, play for 1 second…
Tried a couple of suggestions about cache size, disabling HTTP2, etc yadda yadda, until i came across this thread.
Restored to 4.10.2252.5 (the newer one of the two libraries with that version) with Inpustream Helper, et voilà, i can binge trash TV again (and tonight also the Super Bowl).
Thanks a bunch, i hate having to switch to the official apps on my smart TV for this.
