I tried to install a Prime Addon onto my Pi 3 OSMC 2021-08-1 from the instructions here:
It all seemed to work but the final play of a video failed.
The log is here:
https://paste.osmc.tv/wucexadeja
Can anyone advise?
Thanks, David
The log is here:
Can anyone advise?
Thanks, David
Browsed through the guide, the Netflix part is using my old installer. That sets up cryotodomex module which is as i understood it, needed for any libwidewine addon So i guess it’s not done or you are not using the latest sandman version.
I have since write a new thread for just libwidevine install, that preps your os for those add-ons.
Edit: link to new prep script
