Hey guys, I’m new around here
I am seeing a few errors in my log and would like to know how I fix them.
EDIT: Link Removed
EDIT: Link Removed
Exactly what errors are you talking about? I don’t see anything in your logs that catches my eye as being a problem.
So all those WARNING and ERROR messages such as CSkinInfo: failed to load and EXCEPTION: Non-Existant Control 300 are fine?
Remove the banned addon. It looks like it may be causing those errors, or contact the author of that addon.
To get a better idea of our piracy policy, please see this link here FAQ - OSMC Forums
Oh I see, thanks
I was following a guide and it was the first they said to install. I will try removing it and see if that helps. Thanks
Don’t install things unless you need it.
I’m learning that’s the best way Sam
