Only a wild shot, but I suggest you try to disable the webserver and see if the problems still persists
Can you try setting âresample qualityâ from GPU to medium (in system/audio settings).
Also for me. My Pi 2 freeze time to time (stop music, no more IR response, no web response, Yast doesnât see it anymore)?
I use OSMC since several months. This issue is due to the April update âŚ
Here is my logs (two freezes)
http://paste.osmc.io/afiqovekaz.xml
http://paste.osmc.io/uborigavih.xml
It restart after an ssh and
% sudo systemctl restart mediacenter
Thanks for your help.
Have you tried my suggestion from previous post?
Hi popcornmix,
Thanks for your answer⌠I will try.
I will also try the suggested change to resample quality from @popcornmix above and report back.
In terms of this being related to the April update I am pretty sure it is as I had the March (and all previous) updates applied and didnât have any issues until first reboot after April update was applied.
Having a similar issue. Havenât used the Pictures viewer lately, but when I tried last night it would only show a few of the pictures in the folder. I would select a picture and the screen would black out.
05:01:39 51833.347656 T:3024302640 ERROR: Window Translator: Canât find window settingsprofile
05:01:45 51839.187500 T:2493510640 ERROR: COMXCoreComponent::WaitForEvent OMX.broadcom.image_decode wait event 0x00000003 timeout 1000
05:01:45 51839.187500 T:2493510640 ERROR: COMXTexture::Decode WaitForEvent:OMX_EventPortSettingsChanged failed (80001011)
05:01:45 51839.187500 T:2493510640 NOTICE: DecodeJpegToTexture: unable to decode to texture special://masterprofile/Thumbnails/6/69acba51.jpg 270x210
Have been having a freeze issue since April update on two piâs
Audio drops out then couple seconds later video freezes.
Have since noticed looking at the codecinfo on some videos the aq and ad both constantly are -negative and decreasing in value as the video plays. I can get through a whole video without a freeze but this is happening on virtually all expect those that pass through is running.
And is the same on both piâs.
Will have to check logs.
I did this and have been using OSMC all day (with constant party play) and no freezes yet. This could be the culprit.
It might just be my imagination, but it seems the audio is back to normal now. After the April update it seemed to me that the magnitude of the output volume had decreased.
I will monitor the behaviour with the logs on for a few days and report back either way.
Iâm having the same issue: Audio drops out and after some seconds, my raspberry hangs
Before April update, Iâve never had any freeze.
Here is my log: http://paste.osmc.io/acafuvazol
And have you tried my suggestion?
Thank you for the reply.
Not yet. I usually use âGPU accelerationâ and I have an A/V decoder with passthrough.
Iâm going to follow your suggestion.
Can you explain what does it means this option?
I can confirm exactly the same. With the march version, I had the same configuration without issues
GPU accelerated resampling offloads audio resampling to the GPU. This is useful for Pi1 where CPU is in limited supply, but less critical to Pi2 and Pi3.
For the March update, there was a known bug that could cause kodi to hang when multiple connections to the GPU were being opened/closed. It was believed that GPU accelerated resampling was one of the causes of this, so it was disabled by default on Pi2/Pi3 where it wasnât really needed. It was left enabled on Pi1.
The April update fixed the bug with the GPU connections, and GPU accelerated resampling was enabled for all again. Now it is possible that the GPU accelerated resampling bug was something else and so enabling it again was undesirable. I need people who are experiencing the bug to test with it disabled to confirm whether this is really the cause of the hangs you are seeing.
Thank you, @popcornmix, for your very detailed explanation.
Iâve already changed the configuration. I let you know if I will notice again the freezes
Like jimmyjon, my OSMC played radio all this day (13hours) without any freeze after setting âresample qualityâ from GPU to medium on my Pi2. Thankâs to popcornmix.
I have the same issue. In my case the system freezes when Iâm navigating in the movies or tv show list.
Changing the resample quality didnât solve the issue
RPI1 and OSMC Skin
Here is my log: http://paste.osmc.io/bonekigiqi
Hi magorrias,
Have you tried the popcornmix suggestion ?
If not, could you try and report your result here ?
Thanks.
Doesnât fix the issue on my Pi1.
Yes, Iâve tried with all the âresample qualityâ possibilities and the issue persists
More info: If I navigate very slowly (with CEC) the issue happen less often. But when I navigate quickly the system freezes immediately
