Unable to use xbox controller, i tried following commands:
Error couldn’t claim the USB interface: LIBUSB_ERROR_BUSY
Try to run ‘rmmod xpad’ and then xboxdrv again or start xboxdrv with the option --detach-kernel-driver.
– try the commands
rmmod: ERROR: Module xpad is not currently loaded
root@osmc:/home/osmc# modprobe xpad
root@osmc:/home/osmc# rmmod xpad
root@osmc:/home/osmc# xboxdrv
root@osmc:/home/osmc# xboxdrv --detach-kernel-driver
Error couldn’t claim the USB interface: LIBUSB_ERROR_NOT_FOUND
If I try the full command to get xboxdrv working with --detach-kernel-driver
[ERROR] USBController::on_write_data(): USB write failure: 12: LIBUSB_TRANSFER_ERROR
Any ideas?
(I saw the update and I navigated with the controller to update, after the update it didn’t work anymore.)
osmc@osmc:~$ cat /proc/version
Linux version 4.4.3-3-osmc (root@rpi2) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP PREEMPT Tue Mar 1 15:51:08 UTC 2016
Something must have gone funky with xboxdrv and libusb in the 4.4.6-3 kernel. I wonder if it’s specific to RPI?
When you reinstall the previous kernel, it should just update that package. Other packages should still be current (i.e. Kodi 16.1). So its not a fresh start. Hopefully apt-get would warn you if there were any dependency problems (i.e. if something required the latest kernel). Xboxdrv worked for me once I rolled back, so hopefully it doesn’t cause any new problems.
Thanks for the tip! Is there a list somewhere with the releases? A quick google didn’t do the trick.
Looking for the version before september, somewhere around that time they introduced the random freezing bug and for some reason the old image I installed auto updated to a newer version now I just replug the pi when it crashes. If I could downgrade like this, that would have saved me alot of time.
Here is one way to get a list of the available rpi kernels in the repo
apt-cache search . |grep image
Here are the current ones
rbp1-image-4.4.6-3-osmc - Linux kernel binary image for version 4.4.6-3-osmc
rbp2-image-4.4.3-3-osmc - Linux kernel binary image for version 4.4.3-3-osmc
rbp2-image-4.4.6-3-osmc - Linux kernel binary image for version 4.4.6-3-osmc
Doesn’t seem like there is an older 4.4.3-3 for rpi1, so I’m not sure how you’d roll back on that hardware.
The earliest kernel version that worked with xboxdrv. An image like 2016.02-4 would also be good.
journalctl of an OSMC where it works
journalctl of an OSMC where it doesn’t work
I have an Xbox 360 controller that is wired. Will I be able to use this with XBOXDRV to test? If so, can someone give me a quick rundown of how I can get it running.
I never had any problems with Octobers update last year.
I could give you a journalctl of it not working but it will be a while as I am pull 12 hour shifts this week. Maybe someone else can help? Thanks for looking into it. I opened the issue.
It is from xboxdrv not working, as I mentioned in the previous post. My apologies. Anyways I tried. I cannot get both journals for maybe two weeks. I’ll edit my post. Didn’t know about paste.osmc.io sorry. Cheers.
Edit for grammar
I used this guide [How-to] Xbox 360 Controller OSMC to install my wired controller.
It still works after the April update but the lights on my controller keeps blinking which is a little bit annoying when using it in my bedroom.
Controller: Microsoft Xbox 360 Wireless Controller
Vendor/Product: 045e:0291
USB Path: 001:004
Wireless Port: 0
Controller Type: Xbox360 (wireless)
– [ ERROR ] ------------------------------------------------------
