I have been struggling the last couple of days to get my Argon One IR Remote to work. I have followed countless articles that either don’t work or break the OS. But finally I got the irrecord to work and output a lircd.conf file, however the remote still does not work under OSMC. Am I missing something? What else can I check?
My Configuration:
- ArgonForty Argon One M.2 Case https://www.argon40.com/argon-one-m-2-case-for-raspberry-pi-4.html (IR receiver pad provided by the Argon One case is connected to GPIO 23 (physical
pin 16. Its on the hat PCB and cannot be changed) and appears to provide a 10k Ohm pull up resistor. The supply voltage for the IR receiver is 3.3 Volts. I guess it is TL1838) - Argon IR Remote for Argon ONE V2 and M.2 Cases https://www.argon40.com/argon-ir-remote-for-argon-one-v2-and-m-2-cases.html
- Raspberry Pi 4 booting of SD card
- OSMC November 2020 2020.11-1 ([TESTING] Kodi v19 builds for Raspberry Pi 2/3/4)
- OSMC Updated (25.5.2021)
Procedure:
osmc@osmc:~$ sudo nano /boot/config.txt
/boot/config.txt:
# Warning: do not edit this file, or it could prevent your OSMC system from starting.
# If you wish to make changes, you should do so via My OSMC or edit the config-user.txt file in this directory
# Any changes that you make here will be overwritten as this file is managed by the OSMC via the update system
[pi4]
dtoverlay=rpivid-v4l2
arm_64bit=1
kernel=kernel.img
[all]
dtoverlay=vc4-kms-v3d,cma-512,lirc-rpi,gpio-ir,gpio_pin=23
disable_overscan=0
start_x=1
disable_splash=1
disable_fw_kms_setup=1
include config-user.txt
osmc@osmc:~$ reboot
osmc@osmc:~$ sudo systemctl stop lircd_helper@lirc0
osmc@osmc:~$ sudo irrecord -d /dev/lirc0 /home/osmc/lircd.conf
Running as regular user osmc
Using driver devinput on device /dev/lirc0
irrecord - application for recording IR-codes for usage with lirc
Copyright (C) 1998,1999 Christoph Bartelmus(lirc@bartelmus.de)
This program will record the signals from your remote control
and create a config file for lircd.
A proper config file for lircd is maybe the most vital part of this
package, so you should invest some time to create a working config
file. Although I put a good deal of effort in this program it is often
not possible to automatically recognize all features of a remote
control. Often short-comings of the receiver hardware make it nearly
impossible. If you have problems to create a config file READ THE
DOCUMENTATION at https://sf.net/p/lirc-remotes/wiki
If there already is a remote control of the same brand available at
http://sf.net/p/lirc-remotes you might want to try using such a
remote as a template. The config files already contains all
parameters of the protocol used by remotes of a certain brand and
knowing these parameters makes the job of this program much
easier. There are also template files for the most common protocols
available. Templates can be downloaded using irdb-get(1). You use a
template file by providing the path of the file as a command line
parameter.
Please take the time to finish the file as described in
https://sourceforge.net/p/lirc-remotes/wiki/Checklist/ an send it
to <lirc@bartelmus.de> so it can be made available to others.
Press RETURN to continue.
Usually you should not create a new config file for devinput
devices. LIRC is installed with a devinput.lircd.conf file which
is built for the current system which works with all remotes
supported by the kernel. There might be a need to update
this file so it matches the current kernel. For this, use the
lirc-make-devinput(1) script.
Checking for ambient light creating too much disturbances.
Please don't press any buttons, just wait a few seconds...
No significant noise (received 0 bytes)
Enter name of remote (only ascii, no spaces) :argonforty
Using argonforty.lircd.conf as output filename
Hold down an arbitrary key
Found gap (107949 us)
Please enter the name for the next button (press <ENTER> to finish recording)
KEY_UP
Now hold down button "KEY_UP".
KEY_RIGHT
Now hold down button "KEY_RIGHT".
KEY_DOWN
Now hold down button "KEY_DOWN".
KEY_LEFT
Now hold down button "KEY_LEFT".
KEY_OK
Now hold down button "KEY_OK".
KEY_INFO
Now hold down button "KEY_INFO".
KEY_HOME
Now hold down button "KEY_HOME".
KEY_BACK
Now hold down button "KEY_BACK".
KEY_VOLUMEUP
Now hold down button "KEY_VOLUMEUP".
KEY_VOLUMEDOWN
Now hold down button "KEY_VOLUMEDOWN".
KEY_POWER
Now hold down button "KEY_POWER".
Successfully written config file argonforty.lircd.conf
osmc@osmc:~$ sudo systemctl start lircd_helper@lirc0
Then I went to My OSMC > Remotes > Browse and import argonforty.lircd.conf, unfortunately it just not work. I have tried rebooting, recreating the lircd.conf file but OSMC just doesn’t respond to the IR remote.
argonforty.lircd.conf:
# Please take the time to finish this file as described in
# https://sourceforge.net/p/lirc-remotes/wiki/Checklist/
# and make it available to others by sending it to
# <lirc@bartelmus.de>
# This config file was automatically generated
# using lirc-0.9.4c(devinput) on Tue May 25 12:17:02 2021
# Command line used: -d /dev/lirc0 /home/osmc/lircd.conf
# Kernel version (uname -r): 5.10.32-1-osmc
# Remote name (as of config file): argonforty
# Brand of remote device, the thing you hold in your hand:
# Remote device model nr:
# Remote device info url:
# Does remote device has a bundled capture device e. g., a
# usb dongle? :
# For bundled USB devices: usb vendor id, product id
# and device string (use dmesg or lsusb):
# Type of device controlled
# (TV, VCR, Audio, DVD, Satellite, Cable, HTPC, ...) :
# Device(s) controlled by this remote:
begin remote
name argonforty
driver devinput
bits 56
eps 30
aeps 100
one 0 0
zero 0 0
pre_data_bits 72
pre_data 0x23
gap 107949
toggle_bit_mask 0x0
frequency 38000
begin codes
KEY_UP 0x3F010000001197
KEY_RIGHT 0x5B01000000118C
KEY_DOWN 0x59010000001193
KEY_LEFT 0x5701000000119C
KEY_OK 0x51010000001198
KEY_INFO 0x57010000001196
KEY_HOME 0x56010000001181
KEY_BACK 0x57010000001197
KEY_VOLUMEUP 0x5A010000001194
KEY_VOLUMEDOWN 0x50010000001198
KEY_POWER 0x55010000001197
end codes
end remote
I read some threads that you have to disable the HiFiberry in dtoverlay as it is in colflict with PIN23. I don’t know if that is my problem or not. I don’t have a HiFiberry in there, but I also cannot find the command to do it. But its strange that irrecord works and OSMC does not. Is there maybe another place that I need to set Pin23 in OSMC for IR?
Thanks in advance!
